PiBot GRBL CNC?
Discussion in 'Digital Design and Fabrication' started by SteveT44, Dec 4, 2015.
  1. SteveT44
  2. rcengr
    I don't have any direct experience with that setup, but it does look decent. The premade cables are a big plus and the TB6600 drivers are pretty common and should have no problem driving NEMA 23s.
    Are you building your own or are you going to buy a pre-built system? Recently Sparkfun.com came out with a complete router system you may want to check out.
  3. SteveT44
    I see Sparkfun is selling the Shapoko router which started on Kickstarter. It's a nice design but only has a 16" x 16" cutting area. I'm working up my own design with a 2' x 4' area.
    I have been planning to repurpose the motors from the Ormerod2 (which sucked horribly after early hopes) to make a CNC router using a nice trim router that's been sitting in the box since I got it for the purpose. The PiBot package look slike it will make this much easier. I'm about half as ambitious as Herr Tyng, looking at cutting 12"x48" plywood.
    Panzer likes this.
