Planked deck
Discussion in 'Construction' started by David, Jul 27, 2009.
  1. David
    David Member
    At NATs there were a bunch of guys with really cool planked decks. I drew on lines with a pencil, and it looks good, but how do I apply the epoxy? Should I sand it down after every coat, or will that make it opaque?
    I used poly-var on my Hood's decks. I did not sand between coats (3).
    I have not tried the epoxy, so someone else will have to answer that.
  3. Gettysburg114th
    Mikey will be able to let you know how the Poly-var holds up during the Conference.
    Thanks,
