Pump Control Question
Discussion in 'General' started by Radioman, Apr 5, 2023.
  1. Radioman
    Radioman Active Member
    Franklin Wisconsin
    Do I use a esc for pump control? I do have the BC control board. Do I use a separate battery for the pump?
  2. bsgkid117
    Its up to you? Is this a brushed motor pump? If yes, a pump switch (like a BC pump switch, or the switch on a BC multi-board) will work just fine. You can use an ESC if you wanted to be able to throttle the pump up and down...but its not necessary.
    If this is a brushless motor pump, then an ESC is mandatory.
    As for separate battery for the pump, some build their boats this way, yes. Others dont. It's a personal flavor kind of thing.
