Query for Canadian battlers!!
Discussion in 'General' started by Tugboat, Sep 11, 2010.
    I have a question for the Canadian battlers among us. A fellow who lives up there, who has joined the Cheapest Point of Entry class has asked me if he can use 6mm ply vice 1/4", as his local stores do not sell in Imperial measures. I would expect that 6mm is fine (since it's thinner than 1/4"), but I could also swear that I've heard/read that it is acceptable to use 7mm ply vice 1/4". I told NativeCaptain that I would have no problem with 7mm, but that I was not in one of his local clubs. What do you Canadian gentlemen say to the conundrum?
  2. Jay Jennings
    Hey Tugs, just read the other thread posts and if anyone bitches about 7 mm ply (and I don't think anyone would) their shorts are too tight!!! For my US pals, 1 mm is less thatn 1/25 of an inch!
    For you CDN Capts, check Micheals craft store ( if you send your wife in, no one will know) they have 1/4 inch ply there ( at least in Halifax they do).
  3. absolutek
    i dont think any body in the ontario attackforce would care.. the more boats the merrier. i find it hard to believe he cant find 1/4" ply though. all our hardware stores sell primarily in imperial units. the home despot, rona, and lowes i have near my house carry 1/4" ply even if it is a lower grade.
  4. Chris Easterbrook
    Most stores up here sell in both mesurement styles to. very odd where is he located.
  5. nativecaptain
    nativecaptain Member
    they sold imperial in full sheet
  6. Chris Easterbrook
    Now that is very odd you could by full sheets and cut them up or buy the 7mm its pretty close and as long as a standard 150psi BB can penatrate it you should be fine.
  7. jadfer
    Penetrate the plywood???
  8. absolutek
    Uh no, you dont want to be using 1/4" or 6/7mm plywood for your skin so you don't need to penetrate it.
    It's the new drop test... your 1/2" thick sheet titanium hull skin must penetrate 0 out of 5 times to pass ;)
  10. nativecaptain
  11. CURT
    No issue here getting the thickness needed and I would not have an issue if it's a little thicker .
  12. Tugboat
    Thanks, guys. I was pretty sure it was okay, it's not like 7mm is a LOT thicker than 1/4".
  13. Jay Jennings
    Yeah, it is just over 25/1000 of an inch. Can see anyone complaining about that.
