Regulator Conversion
Discussion in 'Weapons & Pneumatics' started by tgalx3, Aug 29, 2025.
  1. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    Does anyone have the link to the part that can convert the long heavy regulator from the truck supplier to the shorter style.
    apologies, I can’t think of the name of the company that makes the truck regulators that are available to us.
    I thought @Kotori87 had it at one point. Not sure though.
  2. tgalx3
    Snohomish, WA
  3. Justin Ragucci
    Rockaway NJ
    The regulators are from Poly Perfomance I wonder if @bsgkid117 would have the info for the conversion or know where to find it.
  4. tgalx3
    Snohomish, WA
  5. tgalx3
    Snohomish, WA
    It cuts the length down by about half.
    Anvil_x likes this.
  6. Anvil_x
    love it. hey so how'd you get it on? does it need that nylon spacer to work like the pre-conversion?
    tgalx3 likes this.
  7. tgalx3
    Snohomish, WA
    I just put a liberal amount thread tape on and tightened as much as I could.
    Anvil_x likes this.
  8. tgalx3
    Snohomish, WA
    no. It does not need the nylon spacer anymore. It uses the O-ring on the bottle valve for a seal. I can’t remember the specific name of that connection type.
    Anvil_x likes this.
  9. Nomercy
    Nomercy Well-Known Member
    Maryland
    So technically according to the IRC rules, you have messed with the high side of the regulator which is a big no no. I haven't looked in the rules recently but I know it used to be in there. Ya might wanna take a look.
  10. bsgkid117
    What was replaced/modified here is a standard CGA gas bottle adapter, I would make the argument that it's not actually part of the regulator at all.
  11. tgalx3
    Snohomish, WA
    I interpret 'high side' as not messing with the internal components in order to get more/less than 150 psi out of a stock regulator.
  12. Nomercy
    Maryland
    Till it goes thru the regulator is high side. Period.
  13. Nomercy
    Maryland
    I would disagree. They removed a component of the regulator that was installed by the manufacturer. Therefore they messed with the high side of the reg.
  14. tgalx3
    Snohomish, WA
    in your view, if a regulator breaks and we can replace the part, that’s illegal because it wasn’t repaired by the manufacturer?
  15. tgalx3
    Snohomish, WA
    I’ll make a note to bring an extra regulator to NATS. Just in case the CD tells me to change it.
    Nomercy likes this.
  16. bsgkid117
    "The regulator serves to divide the system into a high-pressure side, consisting of the CO2 tank and pressure relief valve."
    As the "high side" is defined, consisting of the CO2 tank and pressure relief valve (burst disk), no high side components were modified here.
    The historical interpretation (your interpretation) of "high side" has been incorrect. If we ran with your interpretation, shimming regulators and such at NATS to pass check in would be illegal.
    GOOD. DAY. SIR. :laugh:
  17. bsgkid117
    This is always good practice. Two is one, one is none, ideally bring 13 of everything and you should survive the entire week.
    Anvil_x and tgalx3 like this.
  18. Nomercy
    Maryland
    We will agree to disagree
  19. Nomercy
    Maryland
    Technically I guess yes.
  20. GregMcFadden
    Here is the rule: as long as everything on the high pressure side is rated for that pressure then it is not a violation of the rule set below.
    The reason it becomes an absurd interpretation in this case is because we can just go back to that manufacturer and ask them to sell us. Just the regulator portion of that initial assembly do exactly the same thing and then comply with what you're asking. That is why your interpretation makes no sense.
    2. All CO2 systems must have a commercially manufactured pressure regulator set to no more than 150 PSI. The pressure regulator must be connected to the tank using only manufactured hoses or unions rated for CO2. The regulator serves to divide the system into a high-pressure side, consisting of the CO2 tank and pressure relief valve, and a low-pressure side, consisting of a distribution manifold, poppet valves or solenoids, and conventional R/C BB cannons. Items on the low-pressure side of the regulator do not need to be commercially manufactured or certified.
