removeing the resin from a Team Delta board
Discussion in 'General' started by Powder Monkey, Aug 3, 2008.
  1. Powder Monkey
    one of our members has a question can any one help him ?
    Does anyone know if it is possible to remove the resin from a Team Delta board and how to do it. I have a relay that is broken and Team Delta will replace it if I can get the resin off. Any help out there? Don
    hmmm... I would use the tip of a very sharp exacto knife, trace a square outline around the relay in the expoxy, and slowly start chipping away at the epoxy layer inside, using the knife blade to try and lift up small sections at a time. You'll only need to get the epoxy around the base of the relay, and over the solder contacts underneath (if it's on that side, I don't have one in the house to look at).
    You'll eventually need a desoldering tool (aka a solder-sucker) and a soldering iron to remove the solder that holds the relay in place.
    Monk, did you get my email?
  3. Powder Monkey
    Thanks Tug and no havent got any thing from you in a while [V]
    I sent it in a pm... I'll send it direct this time.
  5. Powder Monkey
    got it sounds good [:D]
