Save the UTAH
Discussion in 'Vendor News' started by modelshipsahoy, Nov 24, 2018.
  1. modelshipsahoy
    modelshipsahoy Vendor
    Michigan
    The Florida Class Dreadnaught Molds arrived today. F5E5A25F-640C-4161-BFD1-1FCCB2364A55.jpeg They have very nice detailed casements and the mold surface is in decent shape. They are the bulged version with a target beam of 8.83 Inches.
    C9671B62-DA25-45A9-B177-AE50FDB44581.jpeg Sadly they suffer from thin construction and have warped keels from 10 years of shrinking.
    Will begin the process of blueprinting them this evening after I get a protective layer of sacrificial gel installed.
    Lou, FishNHard, Beaver and 3 others like this.
  2. modelshipsahoy
    Michigan
    Beaver and WillCover like this.
  3. modelshipsahoy
    Michigan
    The Starboard side was able to slip into the Doc thanks to the need for a 1/12 copy of the 1955 Gold Cup Winner Gale V... a boat 2 family members worked on and drove.
    Lou and buttsakauf like this.
  4. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    Got to see a contemporary of that boat recently at the Reno Air Races. On a trailer... but I did get to hear it start. Glorious!
    modelshipsahoy likes this.
  5. modelshipsahoy
    Michigan
    So tonight... Lines came out very straight in the keel
    But sides shrank. Beam at casements should be 7 5/8”. They measured in at 7 1/4”.
    Tricky part to that is the measurement for max beam is way low on the boat, so I first built a thwart at 8.83” and installed it low in the bulges.
    That made the deck beam at the casements way too big.
    So I had to call in Dr. Clamps to fix what Ails it.
    Overall I think the lines look good now, but this whole structure is under Buku stress, so Ima Let this sit overnight and think about who she is, what shes done, and how she can get back to the way things used to be.... plus I have 6 boats to ship so I gotta go.
    If Dori asks...I wasn’t here.
    Beaver, Evan Fowler, Lou and 2 others like this.
  6. modelshipsahoy
    Michigan
    Sitting 3 days in clamps while I caught up on powerboats the sides gave back 1/4” toward normal.
    So back in the clamps and a really thick lip of low catalyzed glass (to stretch out the exotherm time) with the equivalent of a 1/2” rod of solid glass laid in flat to set the lip.... but I seriously just sold 3 more powerboats in the time it took me to set this up... so it’s back to the go fasts.
  7. modelshipsahoy
    Michigan
    The first glass template is cut to super tight tolerance. Lol. Turrets will be rock solid double layers with 4x at the seams.
    Beaver and buttsakauf like this.
  8. modelshipsahoy
    Michigan
    Update:
    With the thwart and clamps removed the hull is just 3/16” narrow of the design at the deck casements. Was really hoping I wouldn’t have to go the distance and feed this thing a rib dinner.
    I have to strip this gel out (it gave its life protecting the molds) and spray in new before I can reinstall the thwart and clamps to set ribs properly. The lines all look good and I’m tempted to call it good for the moment. What do you guys think?
  9. buttsakauf
    Garland, TX
    If the extreme beam is within tolerance of the rule set and everything appears nice aesthetically, I would just leave it be. A hull is easy to tweak a touch at the deck if someone is really that worried about it. Don’t forget there is going to be a skin on it as well that adds an 3/32” to 1/8” of beam generally.
  10. modelshipsahoy
    Michigan
    I just can’t do it. Here’s a funny thing about me. I drive a 20 year old truck that is hot wired to start since the ignition switch went bad. That doesn’t bother me one bit... I tell the kids that’s my security system. Lol.
    But when it comes to making scale ships, I like them done right. So I spent a couple hours setting this thing right and bracing it out to spec. Tomorrow I will laminate them thar ribs and be ready to make nice hulls Sunday.
  11. buttsakauf
    Garland, TX
    Kudos to you. Those hulls are gonna be great!
  12. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    ...GREAT TIM!!the FIRST step is always admitting you have a problem....see you at the next meeting....:laugh:
  13. modelshipsahoy
    Michigan
    While Buttsakauf is enjoying his New Baby... I’m here getting closer to making him a couple more Dreadnaught Babies. Congratulations Mike!
  14. modelshipsahoy
    Michigan
    Beam 8.8”, 7.625” at the casements. Lines all look GREAT!
    Surgery Successful... Nurse, Roll this patient to recovery for a haircut. 169B3837-DB7D-451D-B098-1376475AD7D3.jpeg D4D8FEAF-7891-4E3C-806E-BAEF91337FC0.jpeg
    buttsakauf, Beaver and Kevin P. like this.
  15. Evan Fowler
    Evan Fowler Well-Known Member
    Muskegon, MI
    You work some fiberglass magic ;)
  16. modelshipsahoy
    Michigan
    Thanks Evan!
    Before and after pics...
    Hull #1 being laid up tonight.
    buttsakauf likes this.
  17. buttsakauf
    Garland, TX
    Laser straight. Wow!
  18. modelshipsahoy
    Michigan
    We use strand roving for strength and filling hard corners. Makes for really solid built in stringers and ribs. Hull skin and first layer of armor installed... tomorrow night, we jam the Beatles and Come Together.
    ED5AE69E-FFAE-4D50-99C8-B4B2E8FF6D7A.jpeg 091AAE0E-7109-40C9-BE60-58ADBE627BF3.jpeg 4C57818D-F188-4B06-BFD9-341449E8BDC6.jpeg
    Beaver, buttsakauf and WillCover like this.
  19. Evan Fowler
    Muskegon, MI
    Planning on note book and stenographer for our get together :cool:
  20. modelshipsahoy
    Michigan
    Finally! 3# 14.5oz uncut. Sides are a solid glass packed 3/16” thick all around.
    A481FC74-6BDA-43A2-9864-CE080FC58804.jpeg EB095497-7751-4FC1-8988-4B834CC856F3.jpeg 476F709E-458B-4BC0-8D53-D5C78B924CA1.jpeg
    Strangely Alien looking Stern.... the Norse God Utah.
    71F5227E-38BA-4E8E-B0CC-6464CBAFECC1.jpeg E235A914-47BF-42E7-95D2-5BC7B0C7B002.jpeg
    Beaver, WillCover and Evan Fowler like this.
