Servos?
Discussion in 'Weapons & Pneumatics' started by Superarp, Feb 7, 2010.
  1. Superarp
    Superarp Member
    What servos do u guys reccomned for firing guns? Turning guns? Rudder servos??
    Thanks
  2. GregMcFadden
    For firing guns, I no longer recommend servos at all, I suggest the use of solenoids and electronic switches to operate them. The KIP solenoids are a good choice, and are available in 6V versions. The clippard maximatics also work but need a higher voltage (the test one I have stops working reliably at about 7.5 volts give or take) and are rated at 12V
    For rudder and any other servos, check out the waterproof servos from traxxas. I suggest ebay for buying them.
    http://www.traxxas.com/products/accessories/trx_accessories_servos.htm
  3. Superarp
    Superarp Member
    Thanks
