ship tactics
Discussion in 'Scenarios / Gameplay' started by warbird300, Dec 11, 2010.
  1. warbird300
    warbird300 New Member
    you need to try to chase the splashs from BBs in front of you because thay will not try to fire in the same place were thay missed twice so then you have a 75-90% of not geting hit.:D
    2. you need as many ships you want for this. you can make a big fireing line by makeing a leader in front and other ships behind you following like a convoy and when a ship is spoted make the leader face port side to the enamy point the all of the guns at the enamy and all the ships do the same and FIRE:laugh: !!!!!!!
    3.you know the 1st thing i said well if you are trying to hit the enamy but thay doing that 1st trick i said well when you fire miss and the enamy is chasing your spashes well dont move the turent wait till the enamy gets to the area were you last missed and fire agen in the same spot then your enamy will be like this... :pinch:!
  2. SnipeHunter
    Have you ever actually battled?
  3. warbird300
    no i havent battled but ive learned the tricks from the history channal
  4. warbird300
    I know another awesome trick when a lowner is somewere but your ships have nothing to do circal around the lowner and fire
    Feel free to ask questions if you want to learn, but offering battling advice is really something you should avoid at this point.
  6. SnipeHunter
    Or maybe learn some common tactics and strategies that are used in the hobby and then suggest modification or counters as opposed to just assuming that something you saw on TV is applicable here. (hint: its not)
    So what boat are you going to build, we can discuss tactics for that class.
  7. warbird300
    shut up your being a jerk SORRY IM NEW:plain:
  8. warbird300
    well case of the high prices i was thinking of buying a fast and low costing RC boat and installing tooth picks on the front and the tooth picks are under water faceing forward
  9. NickMyers
  10. Tugboat
    Jake, fair warning, calling people names will get you banned. Most people on here are adults and can disagree without resorting to insults.
    The fact that you are new does not give you special privileges and should in fact tell you that you shouldn't be suggesting tactics to other people. I know that you're young, but try to relax. Suggestion: Find out what club is near you, and read their rules before you plan your ship or what you want to do. Also, check with your parents to see if they are ready to spend a lot of time learning how to build and battle ships with you.
    Consider this your friendly warning shot across the bow.
  11. warbird300
    ok thank you for the addvise
