Size matters to some and not others
Discussion in 'Research and Development' started by thegeek, Jan 24, 2019.
  1. thegeek
    Working on a smaller full unit pump in the 350 watt range. Output about 95% of the older BC pump. Seems promising because of the radically lower deck height. Hobbyking 2350 kv motor running on 4 LiFe through a 30 amp ESC.
  2. thegeek
    Durability might be a issue, but output looks good with 1/8 inch orifice and Glug Glug outlet.
  3. Kevin P.
    Only 95%? Sounds like you’re letting your standards slip
  4. thegeek
    Might be more. But bucket of water outside in 0 degree weather makes for short and video less tests.
  5. Anvil_x
    It's within a 0.05 deviation, so further testing might determine that it is in the same pump rate class. if it were 2.5 SD or more, then there would be a clear problem.
  6. thegeek
  7. thegeek
    Aluminum. Plastic. Bronze.
    Aluminum was used in this test.
    Beaver and NickMyers like this.
  8. Kevin P.
    Are you producing or just showing off?
  9. thegeek
    Maybe? I was thinking of just making it available from Shapeways. With the plastic body parts in file form, for 3d printing. Only issue is the shaft seal and aluminum top plate.
    I don't want to manufacture them, did that, knock-offs offend me.
    Beaver, Lou and Kevin P. like this.
  10. daisycutter
    daisycutter Active Member
    warspiteIRC likes this.
  11. thegeek
    Parts count is probably 78% Asian, so the screaming souls may write in kanji!
    Having it in your hand makes it feel more like Toyota than Ford.
  12. Anvil_x
    wow. the video finally loaded. that thing is impressive.
    thegeek likes this.
