Sketchup
Discussion in 'General' started by Kotori87, Feb 8, 2009.
  1. Kotori87
    http://sketchup.google.com/
    Has anyone else seen this? I just found out about it today, and I'm wondering if it can be used for our ships. It looks kinda interesting. Not exactly a full-power CAD program, but it's free.
  2. klibben
    klibben Member
    I've used it to design buildings before. It can be used for ships.... but the 3 dimensions can get tricky at times depending on your angle.
  3. Kotori87
    What units does it operate in? Or can you change the settings on that?
  4. radollar2000
    radollar2000 Active Member
    I use it quite alot in my Landscape Architecture studio classes. I'm fairly certain it only uses imperial system, but then again I've never really looked for it. I'll take a look tonight to make sure. On the other, hand if you know what your doing you can make some really interesting models to send to a CNC machine. I'll get some images of the hulls I've made in sketchup.
  5. radollar2000
    Okay so I played around in sketchup a bit and yes it can be switched over to metric.
  6. radollar2000
    Okay so I still can't seem to post pics..grrrrrr! one of these days. [​IMG][​IMG][​IMG]
  7. klibben
    klibben Member
    You can always link...
    let me see if this works...
  8. klibben
    klibben Member
    What exactly are you doing? Don't use the [​IMG]
  9. GregMcFadden
    You are not linking to an image. You are linking to an entire webpage. the source for the picture is listed as :
    http://www2.snapfish.com/slideshow/AlbumID=276389150/PictureID=6818569932/a=109504667_109504667/t_=109504667
    for example. you need to point to a real file from a source that allows linking...
    to do this, I had to put http://render-2.snapfish.com/render...50,480,266 in the ULR field... I do not know how long this will work (or even if it will work for others) as it was found by "right click on image, click properties" "copy address"
  10. radollar2000
    Sweet It works. Thanks guys. So anyway this is a merchant ship I did up to show my fiance sorta what I think her boat may look like. I didn't want to get into to much detail with it as it was just a quick dipiction.
  11. radollar2000
    This is of the USS Mississippi and I was going to try to make my own fiberglass hull but my friend who might have had access to a CNC to make a mold bailed on me.
    I never could get a good Idea of what the sorcouf looked like so I just kinda fuged a few things from the pics I could find.
    Also just remembered that the pro version allows you to export to Autocad and several other different programs.
