Smooth 3d curved areas
Discussion in 'Digital Design and Fabrication' started by thegeek, Mar 18, 2019.
  1. thegeek
    Why are circular areas not?
    Ok maybe overly critical but why can't they be right.
    I have sand paper, and did sand the areas to eliminate the notched curves.
    But I thought it could print round?
  2. Kevin P.
    Carl I think you’re spending a bit too much time behind the keyboard, never would have thought you’d be complaining about print quality
    bsgkid117 likes this.
  3. jcollins
    jcollins Active Member
    Beavercreek Ohio
    What program are you using? SketchUp tends to have visible facets where Fusion 360 has smooth curves.
  4. thegeek
    Pro photographer has sharp eyes forever.
  5. thegeek
    I don't know what program was used to make Nelson super. So it could be a software issue?
  6. SnipeHunter
    Probably not a software issue as much as a settings issue during export. Should be easy to re-export with finer settings and re-print to fix it.
  7. Litch42f
    Litch42f Well-Known Member
    Nevada
    I use sketchup which I think is notorious for terrible curves. I use this stuff to help smooth everything out:
    View: https://www.amazon.com/Smooth-XTC-3D-Performance-Print-Coating/dp/B00PFXK4JY/ref=sr_1_1?crid=1JGU1U54TC60H&keywords=xtc+3d&qid=1552927556&s=gateway&sprefix=XTC%2Caps%2C1134&sr=8-1
    It also adds a protective coating to my PLA prints since PLA doesn't like being in the sun too much. Here is a picture of a barbette I made. It isn't as smooth as a piece of PVC but I probably could have taken more time to sand before and after I applied the XTC-3D.
  8. NickMyers
    Unfortunately at some point in history someone decided that STL files were the best way to convey object information for printing. STL files are essentially a long list of coordinates of how to form the faces of an object tessellated in to triangles. So from whatever nice smooth curve you model in, the resulting output gets turned into line segments as part of a bunch of triangular faces.
    Making matters worse, most slicers and 3d print controllers don't support arc moves, so even if you had a nicely described curve passed to the slicer, the print would still be done in line segments.
    Most decent modelling software can output a pretty high number of faces, which, if you enable it, helps to smooth out the geometry significantly. However, even a nicely curved piece of line segments will take on a chunky shit look if you have to scale it significantly.
    For an example of curves that came out looking curved and not so chunky look at the parts printed for the Deutschland kits ( https://rcwarshipcombat.com/threads/superstructure-assembly-information.445286/ )
    thegeek likes this.
  9. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    Can you post a pic? It kind of depends on how the model was designed and how it was exported into a format that the 3d printer could use.
    None of the commonly available 3d printers can print true circles but, one can usually get close enough.
  10. Charley
    Charley Vendor
    Lancing, Tennessee
    In fusion 360 you have a refinement section under 3d print tab it allows you to change quality. STL's are built with only straight lines with no circular interpolation.
  11. bsgkid117
    What everyone else has said so far. It's a mixture of the program being used, the slicer being used, the fact that .stl's only work in line segments, etc. I've made barbettes and such that are pretty round, but at the end of the day it's still a polygon vs a true circle.
  12. pipi135
    pipi135 Member
    arizona
    In SketchUp you can change how many sides the circle you create has. Default is 27 sides if i remember correctly.
    For future reference for guys doing their own designs...Before you click where you want the circle you can change how many sides it has. Just type in a number (100 seems to be good enough) then click you center point to place the circle. [before you click to place the circle the number of sides is displayed in the bottom right corner.]
  13. NickMyers
    best to just not use sketchUp imo..
