Has anyone tried using a micro solinoid ( View: https://www.amazon.com/dp/B0105UOS4S/ref=cm_sw_r_cp_api_i_E3UhCbP9C2NK7 ) to trigger a poppet valve, instead of a solinoid from battlers connection(or similar)?
you would need a push solenoid,it can and has been done. my Pennsylvania had solenoid actuated poppets. I used discard solenoids from work that were 20v and designed for rapid firing. another cheaper alternative is to go 12v. 12v solenoid (Spartan) can sometimes be found on ebay cheap.
