strike models new big guns
Discussion in 'Weapons & Pneumatics' started by jagg2, Apr 27, 2010.
  1. jagg2
    jagg2 New Member
    i have two questions about the new big guns from strike models
    1 are they any good
    2 can you post pictures ilistating all or most parts
    thanks vary much
    jagg2
  2. Anachronus
    I did not know they were available yet. I suspect they will be good from my past experiences with Strike.
  3. KeriMorgret
    Seattle, Washington
    Jagg2, we have them on the site with pictures and details at http://www.strikemodels.com/products/cannon-big-gun/
    We currently have one model available, with the rest being completed. A poll right now is of little use because of the extremely limited number of cannons that have been sold/distributed in the wild.
    If you send an email via the contact information on Strike's website, we can get back to you to answer any questions you may have.
    Keri Morgret
    President, Strike Models
  4. Kotori87
    Jagg, could you be more specific about what information you're looking for, quality-wise?
    The Strike Models Big Gun cannons are basically BDE cannons with improved materials and manufacturing techniques. I've used a number of BDE cannons, and they are pretty good stuff. The magazine is great, with reliable ammo feed, good air flow, and a good rotation bearing. Strike has improved the lower valve and accumulator, using o-ring seals and a few other modifications to make maintenance easier.
    I only know of two problems with the original BDE cannons. First, the guy who made the original BDE cannons had a bad habit of using under-size accumulators. Without enough air, the cannons would be under-powered, and replacing the PVC accumulators with larger ones was a difficult, time-consuming task that required a lathe. Strike Models specifically took this into account when upgrading the design. Now the cannons come with an appropriately-sized accumulator already, and the o-ring seals make swapping for a different accumulator a matter of minutes. Problem solved.
    The other problem with the original BDE cannons was that the rotation bearing was sometimes loose, causing the magazine and barrels to recoil when firing. This was a problem with how the cannons were assembled, and correcting it required disassembling the bearing and installing a thicker washer. I actually don't know if Strike has corrected this problem yet, but if a couple degrees of wiggle is the only issue the Strike cannons have, I'd say they're doing pretty good.
  5. jagg2
    jagg2 New Member
    thanks kotori
    you pritty much gave me an idea of thes guns
    so thanks
  6. mabgfounder
    mabgfounder Member
    Salem, Virginia
    I have posted the first part of a two part review on the Mid-Atlantic Battle Group site (http://mabg.org/node/371). I have included some pictures of the pieces and parts which make up the cannons as well as of the assembled cannons. Part two will be shorter and cover the firing tests.
