Hi guys, I am trying to build my own stuffing boxs for my drive shafts and rudders. I am using 1/4 brass tubes and two other small tubes to make it down to the 1/8 drive shaft. I am trying to use sodder to join the tubes. I know how to sweet pipes but its not working forthe brass. what am I doing wrong ? do I need special sodder? I rough up the tube and used flux.
Sounds like you are doing it right, sandpaper, flux, blow torch, and the same solder I use for all my electrical work, that combination has always worked for me. Try cleaning both the inside and outside of the tubes with sandpaper, smear on a little bit of flux, insert the smaller tube into the larger one, hit it with the blowtorch till it gets nice and hot, apply solder and let the capillary action suck it into the joint. I normally do it so they end is telescoped and then once i'm all done just cut it so they are all flush with the trusty dremel. Make sure the areas to be joined area clean and make sure you're getting it hot enough, other than that from what you've said I cant think of anything to try differently
The other way is to get the right size brass tube and some oil impregnated bronze bushings and press them into the tubes...
Warning: DO NOT SOLDER THE OIL-IMPREGNATED BRONZE BUSHINGS. THEY WILL BURN!!! Cyanoacrylic superglue (CA glue) works pretty well for that stuff, if you don't have the equipment for a press-fit. Silver solder requires some very serious heat to use. Lead-based electrical solder is much nicer to work with. Just be sure to not breathe the fumes, because it's got vaporized lead in it that can lead to health problems later on.
You can CA them only if you want to be CAing them together every year. I've had two used ships guys did this on. It was a pain fixing them but they now are soldered together. You might be heating the brass too much. If it's too hot the flux will burn and the solder will roll into a ball. heat slow waving the flame around the brass not just on one spot. take the heat off when the flux starts to bubble. Try the solder, more heat, try solder until it melts. Go slow, use the thin solder, the big pipe stuff is for big pipes. If you are using a vise put wood on either side of the brass so the heat does not go into the vise.
Some of the local hobby stores that stock parts for R/C cars will have bronze oilite bearings like these...
