Does anyone on here have Suffren plans that I could copy? I would like to build her over the summer and maybe battle her next year, if eveything goes OK. Thanks
use a program to to clean them up as much as posible, i use GIMP its free, get back ground white,resize, or use paint to print and resize as you print, save paper and time put a scale on the first page you print to test, or just go to a print /copy place.
K. Because the one I bought has a third shaft but no prop and no hardware inside for a third motor. Just let it go and enjoy it?
PMNick, for real ships they had to go to multiple props in order to move enough water (and apply enough power) to get the ship to speed without going to ginormous propellers. For our scale, that's not an issue. And since model boats steer by the propeller wash across the rudder, more wash=better turning. Suffren has 3 props, 2 rudders. By driving the center prop and dragging two, you will have more thrust to get to speed. The twin rudders act as "ducted thrust" deflecting all that thrust to the side, meaning you will turn very well.
