Termite Armour
Discussion in 'General' started by Powder Monkey, Jan 20, 2009.
  1. Powder Monkey
    Just wondering what you all use to secure your Termite Armour. I have BC US Armor and I'm attaching it to plywood and was thinking ......(OUCH that hurt) [​IMG] CA might not do it ( to brittle)and thought id see what every one ells is doing.
  2. Powder Monkey
    [​IMG] No one uses this stuff come on a little help here [​IMG]
  3. radollar2000
    radollar2000 Active Member
    RE: Termite Armour well after I get the Des Moines built I plan on out fitting her with termite armour and I'll let you know...I betting that won't do you any good though.
    RE: Termite Armour maybe a thin layer of RTV? I'll ask Brian K (who makes the stuff) what he recommends.
  5. rarena
    RE: Termite Armour
    Goop, but don't use that on foam, it will dissolve it. I use the caulking tube for foam when attaching to foam or gorilla glue.
  6. Jay Jennings
    RE: Termite Armour Yup GOOP is my choice.Just maker sure it is either Plumbers GOOP or Marine GOOP. You don't need a whole lot and a bit of painters tape will hold it secure for the short time it takes to set.
