The Hernia Challenge
Discussion in 'Warship Builds' started by absolutek, Apr 11, 2018.
Tags:
  1. absolutek
    So I got the urge to build something to help make the allies great again #maga
    It is a Ralph Cole's made hull from Nova Scotia, Canada. Though the scale accuracy may not be quite as good as the BC version, it is quite thick, and the shipping was a lot cheaper.
  2. absolutek
    I marked out the windows the other day. I opted for two stringers on sharp bends in the upper hullform.
    All ribs are 1/4".
  3. absolutek
    To make fitting the fibreglass deck easier, I drilled holes throughout the hull where the windows will be and used threaded rods with nuts and washers to spread the hull out.
    Closeup :
    With the fibreglass deck roughly sitting on the hull:
    I think I will need a few more threaded rods in the bow section to spread the hull out wider, plus some light angled sanding to achieve a nice snug fit and a good bond once I am ready to bond the hull and deck together.
    I will need to cut hatches in the deck first and make fibreglass rims for those hatches to sit on.
    WillCover, SteveT44 and Beaver like this.
