tools
Discussion in 'General' started by klibben, Apr 30, 2007.
  1. klibben
    klibben Member
    Hey guys,
    I'm moving to a new shop at my farmhouse, lots more room and better conditions.
    I have a few dremels with pretty much every concievable attachment, a scroll saw, and a disc/belt sander.
    What else should i get? I'm working on getting a dril press, is there anything else you guys can think of?
  2. JustinScott
    JustinScott Well-Known Member
    A soldering iron & a solder torch
    A multimeter
    adjustable powersupply is optional, but useful
    A CNC machine? :)
    I like the ones you list plus a bandsaw, and milling machine (which I don't personally have, yet :)
  4. klibben
    klibben Member
    milling is a bit out of my league, i do have a solder iron....one of those nifty INSTANT COOL ones! a bandsaw, i was thinking that but couldn't remember the name of it! What exactly is the diff between a band and a scroll saw?
  5. GregMcFadden
    I can recommend a good mini CNC (and how to get it far cheaper than list by doing portions of it yourself)
    other than that:
    Saws
    Files
    Lathe (not small one, get one that can grip 3" or bigger diameter stock)
    jigsaw
    die grinder
    hot box (for aiding in epoxy curing)
    assortment of picks, wrenches, etc.
  6. klibben
    klibben Member
    well yes, i have hand tools... i was thinking of powertools.
    Should i really get a lathe?
  7. GregMcFadden
    a lathe and mill are two tools that you will not know what you will use them for until you get them but you will find them indispensable as you become proficient at their use. I wish I had one (lathe, I have a mill ), I have to beg time on my buddies stuff. (although the mill is more useful for warships in my opinion). Even a manual mill allows you to easily make aluminum gearboxes fit into your ship with ease (they might not look that good but they will work quite well). Lathe allows the making of propeller hubs, turned barrels, etc.
    -Greg
  8. Kotori87
    I agree with archer, a mill and lathe (NOT a wood lathe) are indispensable in modern warship construction. You'll also need a bunch of tools and attachments to go along with those, such as milling bits and a really big chuck for the lathe. The mill is great for all sorts of things like servo trays, cannon manufacturing, and (most importantly) fixing other people's mistakes. Make sure it's a big mill. There have been several times when I stuck a whole boat in the mill (even battleships) to clear out big globs of epoxy that previous owners had poured, and once to cut slots for prop shafts. A lathe can be used for props and turned barrels, but once you add a really big chuck you can make battleship-sized Big Gun cannons.
    A few other handy tools include a large disk sander, a drill press, a spindle sander, and a large band saw. These are very useful for wooden hull construction, but also for other tasks. You'll also want a good shop vac, and maybe even a leaf blower to clear out the dust after an afternoon's building. A soldering torch with a click-on, click-off head is useful for accumulators and manifolds. You'll want lots of storage and organizational stuff. You can never have too much storage, especially for boats. And lastly, lots of hand tools are a must-have. There are lots of specialized hand tools that I can't even name that use daily for maintance.
  9. klibben
    klibben Member
    I have most of the required hand tools and whatnot, i've been in the hobby for close to 6 years now, but i do most of my building at build sessions...
    I think the lathe will be a distant project, as i could use a band-saw and drill press more readily, hopefully i can get both within a year.
  10. JustinScott
    A lathe is a device that spins your metal (or wood)... I haven't needed a lathe more than a couple times, so when I did I just used the drill press. A proper lathe holds the cutter inplace, for my method to work you need a steady hand.
    MILL: Again a drill press is DAMN close. Buy a press attachement like:
    Visit this site
    & poof! you have a mill.
    I think a solder torch (not solder iron) is invaluable.
    YOU can also go crazy & buy one of these:
    Visit this site
    ---> GREG, how/where can you get a cheap mini CNC?
  11. klibben
    klibben Member
    how's this sound for a drill press?
    Drill Press Type
    Bench Top Drill Press
    Type of Item
    Power tools & accessories
    General Features:
    Drill Type
    Drill
    Spindle Speed
    5
    Table Dimensions
    7-5/8 x 6-1/2 in.
    Table Material
    Cast iron
    Table Movement
    Tilt
    Table Swivel
    Yes, 360 deg.
    Table Tilt Range
    0-45 deg. left/right
    Chuck:
    Capacity
    1/2 in.
    Type
    Keyed
    Motor-Engine:
    Horsepower, Maximum Developed
    2/3 hp
    Speed Capability
    5 speeds
    Speed Range RPM
    620-3100 rpm
    Controls, Overall:
    On/Off Type
    Switch with key
    Included with Item:
    Fence
    Yes
    Stop Blocks
    Yes
    $119 (and its got laser x and y axis for alignment)
  12. JustinScott
    a drill press is a drill press IMHO.
  13. Tugboat
    I kinda like having several speeds for working different materials (and yes different drill bits for different materials). I thought the laser alignment "X" to be hokey until I was using it. Now I love it :)
    As long as it's got enough working range (vertical movement of the drill head, i.e. how tall a piece can you drill with it) then I'd say that's a good deal. Did you find it online, or in a store?
  14. klibben
    klibben Member
    sears
  15. JustinScott
    sears.... my home away from home. I REALLY want that mill attachment.
  16. klibben
    klibben Member
    which'n?
    personally i prefer Home Depot...
  17. DarrenScott
    Scroll saw: Blade is short, moves up and down, much like a jigsaw in action. Blades are very cheap. Can handle larger sheets of material than bandsaw.
    Band saw: Blade is continuous, runs around two wheels. Can produce smoother cuts than scrollsaw, especially in polycarb where the scrollsaw blade tends to overheat. Blades are not as cheap.
    Cost for both is about the same.
  18. JustinScott
    This mill attachment:
    Search sears website for #00927593000
