Treaty gun set up
Discussion in 'Weapons & Pneumatics' started by JKN, Apr 1, 2010.
  1. JKN
    JKN Member
    I my self say 3 50s forward with depression would be best but thats me.
    Please tell me what you think.
    I would suggest the two 75 round cannons aft.
    For several reasons.
    First off. Two cannons will be easier to maintain, than three. And will probably be more reliable. And reliability is the most important factor in a ship.
    And cannons in the stern so that you can shoot up any ships that give you chase. That way you are shooting up enemy ships while trying to not give
    them a chance to shoot up yours.
    I personally prefer bow cannons on my ships, but it will more often than not, get one into situations where you have to take damage in order to give
    it.
    You can always change the cannon positions at a later time.
    But for a first ship, it is best to keep things simple, and not try to exchange damage with one's opponants.
    The less damage one takes while on the water, the less time spent patching the damage in the pits. That leaves more time to keep the ship systems
    in opperational order.
  3. JKN
    JKN Member
    How about having 2 75s forward with depression so you could shoot across the pond and when needed shoot close range.
    Then you could stay far away from the enemy and shoot long shots and when they chase you they more than likely have now straight forward guns to shoot you with and Des Moines is one of the fastest ship on the water.
  4. Anachronus
    It's hard enough to hit things with a smoothbore cannon when you are looking down the barrel. Much less shooting across a pond from the shore line. While you can mount two bow guns for long range fire, you will probably not hit much. Also is there an issue with bb's skipping on the water with too flat a trajectory? That could be a safety concern.
  5. JKN
    JKN Member
    This is sort of of topic but how far can a treaty gun penetrate?
    My remington 177 pellet rifle fires pellets and bbs. I have shot through both sides of a soup can with a water bottle with solid ice in the bottle all inside the can and yet I can lay the gun almost flat on water yet the bbs don't skipp.
    The remington is a smooth bore.
  6. Anachronus
    I suspect your Remington has a bit higher pressure than the boats do. Isn't a standard test 2" of insulating styrofoam?
