Treaty rules process for 2010 battling season
Discussion in 'Washington Treaty Combat' started by froggyfrenchman, Dec 2, 2009.
    All
    We are starting phase 1 of the rules process at this time.
    If you have battled at a Treaty event in 2008-2009, then you can propose,
    counter-propose, second, or third rule changes.
    Phase 1 will end next Saturday at noon.
    The founders
    All
    Just cross-posting up-dates for our rules process.
    All
    This year we are posting up-dates on the proposals just to help everyone stay
    informed as to the status of each proposal.
    So far. This is what we have.
    Proposal # 1
    Warship classes time frame.
    Move the start date for launching back to 1895.
    Proposed by Mikey.
    Seconded by Bobo.
    Thirded by Mike D.
    This proposal is set to go to phase 2.
    Proposal # 2
    Rudder area rule.
    Not having to hook up linkages to auxiliary rudders in order to utilize the
    additional 50% rudder area on the main rudder.
    Proposed by Jeff S.
    Seconded by Phil A.
    Proposal # 3
    Pre-dreadnaught side-mount rule.
    Allow pre-dreadnaughts to have side-mounts.
    Proposed by Eric N.
    No seconds. 1 counter-proposal. (below)
    Counter-Proposal to # 3
    Allow pre-dreadnaughts with a beam of at least 70 to have side-mounts.
    Proposed by Mike D.
    No seconds.
    Proposal # 4
    Class 2+3 side-mount rule.
    Allow class 2+3 to utilize (1) unit as a side-mount.
    Proposed by Eric N.
    No seconds.
    Proposal # 5
    Ships with all-forward mounted main turrets.
    Allow (all) ships with all-forward mounted main turrets to utilize a single
    stern cannon.
    Proposed by Mike D.
    No seconds.
    That is it so far.
    The founders.
    This is from yesterday.
    I will post an up-date in a little while.
    All
    Proposal # 1
    Proposed by Mikey.
    Seconded by Bobo.
    Thirded by Mike D.
    Proposal # 2
    Rudder area rule.
    Proposed by Jeff S.
    Seconded by Phil A.
    Proposal # 3
    Proposed by Eric N.
    No seconds. 3 counter-proposals. (below)
    Counter-Proposal to # 3 (A)
    Proposed by Mike D.
    No seconds.
    Counter-Proposal to # 3 (B)
    Widen the bow, and stern quadrants to 60 degrees (total) for ships in class 4 and above (and pre-dreadnaughts).
    Proposed by Mikey.
    No seconds.
    Counter-proposal to # 3 (C)
    Widen the bow, and stern quadrants to 60 degrees (total) for ships in class 3 and above, and any ship with a beam of at least 70'.
    Proposed by Phil A.
    No seconds.
    Proposal # 4
    Proposed by Eric N.
    No seconds.
    Proposal # 5
    Allow (all) ships with all-forward mounted main turrets to utilize a single stern cannon.
    Proposed by Mike D.
    Seconded by Mikey.
    Thirded by Bat.
    Additional supporters.. Bob P.
    This proposal is advancing to phase 2.
    That is it so far, as of Wednesday evening.
    The founders.
    All
    We will kick off phase 1 of the rules process on Saturday November 28 at noon.
    Phase 1 will end at noon on Saturday December 5.
    At that point phase 2 will begin.
    In this phase, any proposals that got the required second, and third supporters
    will be voted on by the folks that have battled to Treaty rules in the last two
    seasons.
    Voting will be done via a poll set up on the Treaty yahoo site.
    Anyone that is not on the yahoo site, will be able to send me their vote
    directly, and I will print them out and keep them on file.
    Phase 2 will last until everyone has voted, or until noon on Saturday December
    12. (whichever comes first).
    At the end of phase 2.
    Any proposal that gets the required two-thirds support of the voting Treaty
    captains, will them proceed to phase 3.
    In this final phase.
    Any proposals that have made it this far will need to get the support of two of
    the three founders, in order to pass.
    Phase three should not last more than a day or two.
    Thanks.
    All
    Sorry for posting out of sequence.
    Just passing along some general info on the process.
    All
    Anyone that has battled to Treaty rules in the last two seasons (2008-2009), that is not on the Treaty yahoo site, can check in either on this site, or contact me directly at MDeskin@aol.com if you wish to propose a rule change, or counter-propose, second, or third an existing proposal.
    Same goes for the voting when we get to phase 2.
    For the time being..
    Perhaps you all can at least check-in if nothing else, just so that we know you are keeping an eye on the process.
    Thanks
    All
    This year we are posting up-dates on the proposals just to help everyone stay informed as to the status of each proposal.
    Proposal # 1
    Proposed by Mikey.
    Seconded by Bobo.
    Thirded by Mike D.
    Proposal # 2
    Rudder area rule.
    Not having to hook up linkages to auxiliary rudders in order to utilize the additional 50% rudder area on the main rudder.
    Proposed by Jeff S.
    Seconded by Phil A.
    Proposal # 3
    Proposed by Eric N.
    No seconds.
    4 counter-proposals. (below)
    Proposed by Mike D.
    Seconded by Eric N.
    Counter-Proposal to # 3 (B) (withdrawn)
    Proposed by Mikey.
    No seconds.
    Withdrawn
    Widen the bow, and stern quadrants to 60 degrees (total)for ships in class 3 and above, and any ship with a beam of at least 70'.
    Proposed by Phil A.
    Seconded by Jeff S.
    Counter-proposal to # 3 (D)
    Allow pre-dreadnaughts with a beam of at least 73' to have sidemounts for the 2010 battling season under R+D.
    Proposed by Mikey
    No seconds.
    Proposal # 4
    Proposed by Eric N.
    No seconds.
    Proposal # 5
    Proposed by Mike D.
    Seconded by Mikey.
    Thirded by Bat, and Bob P.
    Proposal # 6
    Widen the bow and stern quadrants for the larger aircraft-carriers.
    Widen the bow and stern quadrants for aircraft-carriers class 4 and up, with a beam of 80' or more, to 60 degrees (total), (30 degrees to each side of the centerline).
    And the cannons in each quadrant must be evenly distributed to port and starboard of the centerline.
    Under R+D for the 2010 battling season.
    Proposed by Mikey
    No seconds.
    That is it so far, as of Friday morning.
    The founders.
    All
    Some of the proposals, and counter-proposals have been withdrawn.
    So. This is what we have.
    Proposal # 1
    Proposed by Mikey.
    Seconded by Bobo.
    Thirded by Mike D.
    Proposal # 2
    Rudder area rule.
    Proposed by Jeff S.
    Seconded by Phil A.
    Proposed by Phil A.
    Seconded by Jeff S.
    Proposed by Mikey
    Seconded by Mike M.
    Thirds by Eric N., and Mike D.
    Proposal # 5
    Proposed by Mike D.
    Seconded by Mikey.
    Proposal # 6
    Proposed by Mikey
    Seconded by Bob P.
    That is it so far, as of Saturday morning.
    The founders.
    Proposal # 6 has been thirded by Phil A.
    It is also advancing to phase 2.
    The founders
  10. froggyfrenchman
    Phase 1 will end at noon today.
    supporters will be voted on by the folks that have battled to Treaty rules in
    the last two seasons.
    December 12. (whichever comes first).
    Thanks for your participation.
    The founders
    Proposal 3 (C) has a third supporter.
    It also advances to phase 2.
    The founders
    The following proposals have advanced to phase 2.
    We have created polls on the Treaty yahoo site for voting.
    Everyone that has battled at a Treaty event in the 2008-2009 battling season can vote.
    If you do not want to vote via the polls, feel free to e-mail me directly at..
    MDeskin@aol.com.
    I will print out, and file your votes.
    Phase 2 ends next Saturday at noon.
    Thanks for participating.
    The founders
    Proposal # 1
    Proposed by Mikey.
    Seconded by Bobo.
    Thirded by Mike D.
    Proposed by Phil A.
    Seconded by Jeff S.
    Third by Bob H.
    Proposed by Mikey
    Seconded by Mike M.
    Proposal # 5
    Proposed by Mike D.
    Seconded by Mikey.
    Proposal # 6
    Proposed by Mikey
    Seconded by Bob P.
    Third by Phil A.
    All
    Here is an attempt at compiling a list of some of the new pre-dreadnaughts that will be buildable if proposal # 1 passes.
    Great Britain (classes)
    Swiftsure, King Edward VII, Duncan, London, Formidable, Canopus, Majestic, and Renown.
    U.S. (classes)
    Mississippi, Vermont, Connecticut, Virginia, Maine, Illinois, Kearsage,
    Iowa.
    Germany (classes)
    Deutschland, Braunschweig, Wittelsbach, Kaiser.
    France (classes)
    Liberte, Republique, Suffren, Iena, Charlemagne, Bouvet, Massena.
    Japan (classes)
    Mikasa, Shilishima, Fuji.
    Italy (classes)
    Regina Elena, Regina Margherita, Ammiraglio di Saint Bon.
    Russia (classes)
    Ioann Zlatoust, Borodino, Tsesarevich, Kniaz Potemkin-Tavricheski, Rostislav.
    Austria-Hungary (classes)
    Erzherzog Karl, Habsburg.
    Norway (classes)
    Haarfagre, Norge.
    Denmark (classes)
    Herluf Trolle, Skjold.
    Sweden (classes) (coastal-battleships)
    Oden, Dristigheten, Aran, Oscar II.
    Netherlands (classes) Coast-defence
    Koningin Regentes.
    Brazil (classes)
    Marshal Deodoro.
  14. froggyfrenchman
    All
    Less than one day into phase 2, the results are looking very good indeed, with three of the proposals so far getting unanimous support.
    Here is what we have so far.
    Proposal #1 (Move time frame back to 1895 for ships being launched).
    5 yes votes.
    0 no votes.
    Proposal # 5 (All ships with all-forward main turrets can have a stern cannon).
    5 yes votes.
    0 no votes.
    Proposal # 3 (D) (Allow sidemounts on pre-dreadnaughts with 73' or more beam for 2010 battling season), (under R+D).
    5 yes votes.
    0 no votes.
    Although the outcome at this time is still undecided, it is looking very good for these three proposals.
    Proposal # 6 (Widen the bow, and stern quadrants for the large aircraft-carriers to 60 degrees total), (under R+D for 2010 season).
    3 yes votes.
    2 no votes.
    Proposal # 3 (C) (Widen the bow and stern quadrants for ships in class 3 and up, and ships with a beam of 70' or more to 60 degrees total).
    2 yes votes.
    3 no votes.
    The outcome of these last two proposals are still very much in question.
    The aircraft-carrier proposal is getting a little more support than the class 3 and up, but there are still a lot of folks that have not cast their votes yet.
    We will continue to post daily up-dates.
    Thank you.
    The founders
  15. froggyfrenchman
    All here is an attempt at a list of some of the armored cruisers that can be built if proposal #1 passes.
    Great Britain (classes).
    Warrior, Duke of Edinburgh, Devonshire, Monmouth, Drake, Cressy, Diadem, Powerful.
    U.S. (classes).
    St. louis, Denver, New Orleans.
    Germany (classes).
    Roon, Prinz Adalbert, Furst Bismarck.
    France (classes).
    Jules Michelet, Leon Gambetta, Gloire, Dupleix, Gueydon, Jeanne D'Arc,
    Pothaua.
    Japan (classes).
    Kasuga, Adzuma, Yakumo, Asama.
    Italy (classes).
    Garibaldi, Vettor Pisani.
    Russia (classes).
    Rurik, Bayan, Rossia.
    Austria-Hungary
    Sankt Georg, Kaiser Karl VI.
    Sweden
    Fylgia
    Netherlands (class).
    Holland
  16. froggyfrenchman
    All
    An attempt to compile a list of some of the protected, and light cruisers that will be buildable if proposal #1 passes.
    Sentinel, Pathfinder, Forward, Adventure, Gem, Pelorus, Hermes, Challenger, Arrogant, Eclipse.
    U.S. (classes). (armored).
    Tennessee, Pennsylvania, Brooklyn.
    Note.. These are the armored cruisers. I listed the smaller cruisers on the last list by accident. My bad.
    Germany (classes).
    Victoria Luise, Bremen, Gazelle, Hela.
    France (classes).
    Jurien de la Graviere, D' Estrees, Chateaurenault, Guichen, D'Entrecasteaux, Catinat, D'Assas, Descartes, Linois.
    Japan (classes).
    Otowa, Tsushima, Chitose, Suma.
    Italy (classes).
    Umbria (or Regions).
    Russia (classes).
    Zhemchug, Almaz, Bogatyr, Askold, Pallada.
    Austria-Hungary (classes).
    Kaiser Franz Joseph I, Zenta.
    Norway
    Frithjof
    Sweden (torpedo cruisers).
    Ornen, Claes Horn, Jacob Bagge, Psilander, Clas Uggla.
    Portugal
    Rainha Dona Amelia, Dom Carlos I, Sao Rafael, Sao Gabriel, Adamastor.
    Spain (classes).
    Estramadura, Plata, Cataluna, Emperador Carlos V.
    Turkey
    Medjidieh, Abdul Hamid.
    China (classes).
    HaiT'ien, Hai Yung, Tung Chi.
    Argentina (classes).
    Garibaldi, Buenos Aires.
    Brazil
    Barrozo
    Chili
    Chacabuco, O'Higgins, Esmeralda, Ministro Zenteno.
  17. froggyfrenchman
    A list of some ships mined, torpedoed, sunk, or lost in WW1.
    Great Britain
    Majestic,Goliath,Ocean,Formidable, Irresistable, Bulwark, Cornwallis, Montagu, Russel, Britannia, King Edward VII, Triumph, Ariadne, Aboukir, Cressy, Hogue, Drake, Good Hope, Monmouth, Hampshire, Black Prince, Cochrane, Natal, Warrior, Defence, Pegasus, pathfinder.
    U.S.
    California, Tennessee, Milwaukee.
    Germany
    Pommern, Prinz Adalbert, Friedrich Carl, Yorck, Scharnhorst, Gneisenau, Hela, Ariadne, Frauenlob, Undine, Bremen, Leipzig.
    France
    Bouvet, Gaulous, Iena, Suffren, Liberte, Deputit-Thouars, Kleber, Leon Gambetta, Chatteaurenault.
    Japan
    Kasagi, Oowa.
    Italy
    Benedetto Brin, Regina Margherita, Giuseppe Garibaldi.
    Russia
    Slava, Pallada, Oleg, Ochakov, Zhemchug.
    Austria-Hungary
    Wien, Kaiser Franz Joseph I, kaiserin Elisabeth, Zenta.
    Sweden
    Clas Uggla.
    Portugal
    Rainha Dona Amelia
  18. froggyfrenchman
    All
    This post is more for some of the newer folks that may not realize the theory behind the proposed changes.
    For the most part.. These are my oppinions..
    Proposal #1
    Move the time frame back to 1895 for ships being launched.
    Currently, the start date for ships allowed to be built does not go back far enough to allow some of the ships that actually faught in WW1 to be built.
    If this proposal does pass, then more of the ships that were in service, and saw action during WW1 would be allowed to be built.
    We are simply proposing widening the window (or time frame) for ships that can participate.
    Proposal #5
    All ships with all-forward mounted main turrets can have a stern cannon.
    Currently the rules allow capital ships with all their main turrets mounted forward (Rodney, Richelieu, Dunkerque) to arm a single stern cannon in the after superstructure, in order to protect their sterns.
    But the current rules do not mention ships below class 4 (non-capital ships).
    So there are a couple/few cruisers that are allowed to be built, but cannot have a stern cannon. They must have the cannons mounted in the forward part of the ship.
    Some of the ships in question are the Tone, and Oyoda.
    We are simply proposing changing the wording of the current rule covering capital ships (only), with all-forward mounted main turrets
    to cover all ships with all-forward mounted main turrets.
    Proposal 3 (D)
    Allow sidemounts on pre-dreadnaughts with a beam of 73' or more for the 2010 battling season. (Under R+D).
    Currently, all pre-dreadnaughts are in class 3, which means that they are not allowed to carry side-mounts. All of their cannons must be placed in the bow, and stern quadrants.
    Pre-dreadnaughts are basically old battleships. Some have beams that are wider than some of the class 4 ships that can currently have side-mount cannons.
    We are proposing that all pre-dreadnaughts with a beam of at least 73' be allowed to have side-mounted cannons.
    R+D is research, and developement.
    If a proposed change is listed under R+D, for one year, then it allows us to implement the proposed change for a year, while taking a look at the way it affects the game-play, so that we can then take another vote the following year to add it to our rules package.
    In this way, we can then vote on the proposal based more on knowledge gained through experience, and less on theory.
    We are proposing that we implement allowing the larger pre-dreadnaughts the ability to have side-mounts, for the 2010 battling season, so that we can then put it to a more informed vote for 2011.
    Proposal #6
    Widen the bow and stern quadrants for the larger aircraft-carriers with a beam of 80' or more to 60 degrees (total), (30 degrees to either side of the centerline).
    Cannon units must be devided evenly to port and starboard of the centerline.(Under R+D for the 2010 season).
    Currently, the rules allow the aircraft-carriers to have bow, and stern mounted cannons only. They are not allowed to have side-mounted cannons.
    Some of the larger aircraft-carriers have beams in excess of 80-100' or more.
    We are proposing that we widen the bow and stern quadrants for the larger aircraft-carriers to 60 degrees (total), in order to give them more flexability in how they set up their cannons, so that they have more coverage than the smaller ships (like cruisers), but still do not have side-mounts like the larger capitalships (like battleships and battlecruisers).
    In addition. By dictating that the cannons in the bow and stern quadrants be evenly devided to port and starboard of the centerline, these ships will not be able to have twin cannons firing out to the 30 degrees unless they are at least class 7 ships.
    This is also under R+D for one year, so that we can take a look at how it affects game-play, before voting on it again at the end of next year.
    Proposal 3 (C)
    Widen the bow and stern quadrants for ships in class 3 and up, and ships with a beam of 70' or more, to 60 degrees (total).
    Currently all ships have a bow, and stern quadrant that is 30 degrees wide (total). So 15 degrees to both sides of the centerline.
    All ships in class 3 and less (and all aircraft-carriers) must have their cannons mounted in these bow, and stern quadrants.
    We are proposing that the bow, and stern quadrants be widened to 60 degrees (total), or 30 degrees to each side of the centerline, for ships in class 3 and above, and ships with a beam of 70' or more, in order to give the larger cruisers, aircraft-carriers, pre-dreadnaughts, battlecruises, and battleships more flexability in how they mount their cannons in the bow, and stern quadrants.
  19. froggyfrenchman
    All
    Just trying to compile a list of the aircraft-carriers that would be able to utilize the wider bow, and stern quadrant rule if proposal #6 passes.
    This is for aircraft-carriers (class 4 and above), with at least an 80' beam.
    Furious (as originally completed as an A/C), Eagle, Furious, Courageous,
    Ark Royal, Illustrious, Indomitable, Implacable, Eagle (1942 class), Malta.
    U.S.
    Lexington, Ranger, Yorktown, Wasp, Essex, Midway.
    Germany
    Graf Zeppelin
    Japan
    Akagi, Kaga, Shokaku, Junyo, Taiho, Shinano.
    France
    Bearn, Joffre.
    Italy
    Aquila
  20. froggyfrenchman
    All
    Three days into phase 2, the results are looking very good indeed, with three of the proposals so far getting almost unanimous support.
    9 yes votes.
    0 no votes.
    8 yes votes.
    1 no votes.
    Proposal # 3 (D) (Allow sidemounts on dreadnaughts with 73' or more beam for
    9 yes votes.
    0 no votes.
    7 yes votes.
    2 no votes.
    4 yes votes.
    4 no votes.
    The aircraft-carrier proposal is getting a little more support than the class 3 and up, but there are still a several folks that have not cast their votes yet.
    We will continue to try to post daily up-dates.
    Thank you.
    The founders.
