Treaty rules process for the 2011 battling season
Discussion in 'Washington Treaty Combat' started by froggyfrenchman, Nov 28, 2010.
    All
    The rules process for the 2011 battling season starts at 9pm this evening.
    In order to make sure that nobody gets left out of the rules
    process, we would ask that everyone that has battled at a Treaty
    event (to Treaty rules) in the 2009-2010 battling seasons check in,
    and let us know that you are monitoring the process.
    If you anticipate not being able to keep an eye on the process in
    the next two weeks, then make sure you let us know, so that we can
    do what we can to keep you in the loop via phones, or smoke signals.
    Thank you.
    The founders
    All
    We will kick off phase 1 of the rules process at 9pm this evening.
    Phase 1 will end at noon on Sunday December 5.
    At that point phase 2 will begin.
    In this phase, any proposals that got the required second, and third supporters
    will be voted on by the folks that have battled to Treaty rules in the last two seasons.
    Voting will be done via a poll set up on the Treaty yahoo site.
    Anyone that is not on the yahoo site, will be able to send me their vote
    directly, and I will print them out and keep them on file.
    Phase 2 will last until everyone has voted, or until noon on Saturday December
    11. (whichever comes first).
    At the end of phase 2.
    Any proposal that gets the required two-thirds support of the voting Treaty
    captains, will them proceed to phase 3.
    In this final phase.
    Any proposals that have made it this far will need to get the support of two of
    the three founders, in order to pass.
    Phase three should not last more than a day or two.
    Thanks.
    Up-date.
    At this point we have one proposal with enough support to advance to phase 2.
    It would increase the maximum warship speed from 38 knots, to 40 knots.
    There are some other clerical proposals for re-wording some of the stuff that seems to conflict,
    or was integrated from one of the other rule sets.
    The following proposals have the support to advance to phase 2.
    Increase max warship speed to 40 knots.
    Gun control (add timing circuit wording).
    Add class 3 carriers to the long cruiser rudder area rule.
    Have the rules process on even calender years only.
    There are two proposals for making the casements impenetrable.
    Use as-modeled (re-built) tonnage to determine the units.
    It looks like the following proposals have a second.
    Scoring (remove the points table). As we have not been scoring damage points.
    Remove requirement for un-powered shafts.
    There are also quite a few admin type proposals cleaning up conflicts and changing the wording within the rules.
    The following proposals have advanced to phase 2.
    The current maximum warship speed is 38 knots.
    This would give a slight increase in speed to very few light cruisers, and some destroyers that achieved speeds in excess of 38 knots.
    We have had one ship on the water in the past that had a timing circuit installed on one of the cannons.
    The circuit allowed the skipper to hold down the stick, and the cannon was able to continue firing single-shots
    within the rate-of-fire rule.
    We currently allow single rudder cruisers over 630 feet in length an additional 50% rudder area.
    This would add the light aircraft-carriers (most of them built on cruiser hulls) over 630 feet in length to the current rule.
    We currently hold our rules process every year.
    This would mean that we would have the rules process every other year.
    Proposal for making the casements impenetrable.
    We have discussing making the casements hard for the last few years, due to some folks
    avoiding building some of the ships that have casements.
    Making the casements hard would give folks a wider selection of ships to choose from,
    and at the same time, make the building, and maintanance of these ships easier.
    We currently use a ship's as-built standard tonnage to allot units.
    But the ship's speed is based on the as-modeled configuration.
    So some ships that were modernized, and lost some of their speed during the conversion,
    have to run at the lesser speed.
    This proposal would allow ships that were modernized, and may move into the next unit class bracket
    to get the increased units, but they would also possibly have a decrease in their maximum speed.
    There is a proposal to clean up our current rule on cannon units, which is somewhat hard to follow.
    The members are currently deciding if they want to vote on them, or send them on to phase 3.
    The polls will remain open till next weekend, or until everyone has had a chance to vote.
    Whichever comes first.
    Currently, the proposals for the timing circuits, light aircraft-carriers, and cannon-breakdown are all getting unanimous support, and will most likely pass phase 2.
    The proposals for the increased maximum warship speed, hard casements, and as-modeled units allotment are mainly getting support.
    The proposal for having the rules process every two years is getting some support, but is currently failing.
    I will post up-dates later.
    Currently, the proposals for the timing circuits, light aircraft-carriers, cannon breakdown, and hard casements are passing.
    The proposals for increased maximum warship speed, as-modeled units allotment, and having the rules process every two years are failing.
    I will post more up-dates later.
    The polls for voting will close at noon today.
    The status of the proposals remain the same as in my previous post.
    Thanks.
    The polls are now closed.
    I will post the results shortly on the proposals that advance to phase 3.
  10. froggyfrenchman
    All
    The following proposals got the support needed to advance to phase 3.
    Proposal #2.
    Class 3 aircraft-carriers over 630' getting extra rudder area.
    Proposal #3.
    Making the casements inpenetrable.
    Proposal #5.
    Cannon units break-down.
    Proposal #7.
    Allow timing-circuits for firing cannons.
    I will be creating the new polls shortly for the founders.
    Thanks you for your participation.
    All
    The polls for phase 3 are now closed.
    All four of the proposals were approved by the founders.
    We will try to decide on the admin proposals in the next day or so,
    and post those results as well.
    Thanks for your participation in the process this year.
    All
    The founders have approved all of the admin proposals.
    I have listed them below.
    Frequency control.
    Muzzle velocity.
    Class 8 clean up.
    Legal ships table.
    Unit table (admin).
    Club members.
    Safety pressure release.
    Drop test.
    Displacement reference.
    Mark's class 8 reference.
    We are still looking for the ruling on the aircraft-carrier
    sponsons, that I misplaced a couple of years ago.
    Hopefully, we will find it in time to have it added into our
    rules package.
    All
    The rules process is now officially closed.
    Thanks to everyone that took the time to participate.
    And a special thanks to Mark for his endless help with
    all of the rules package stuff. And the ship list.
    Now back to your regularly scheduled program.
    Build-program that is..
  14. Bob Pottle
    Hi Mikey,
    That new rudder rule for light carriers applies only to those that are single ruddered, right? It would be nice to get another 50% area for Ibuki but she's twin ruddered. :>)
  15. froggyfrenchman
    Yes. We already allow the extra rudder area for the single rudder cruisers over 630 feet long.
    The light aircraft-carriers were overlooked when we wrote the original rule for the cruisers.
