Unit allotment
Discussion in 'Washington Treaty Combat' started by froggyfrenchman, Jun 21, 2009.
    All
    Again, this is not a rule change proposal. Just an interesting discussion.
    Currently, units are alloted, based on standard displacement. But some navies figured their standard displacement differently, and some violated the limits imposed by the various treaties, which in some cases means that they get more units than a ship that was built within the limits, by utilizing better weight-savings techniques.
    We have, in the past, discussed the idea of alloting units based on full-load tonnage. And although it might end up being more accurate, and perhaps more fair, it might also still not cover all of the issues.
    There have been the debates for years about how many units this ship should get, or why one ship has more units that another.
  2. crzyhawk
    I don't like the idea of using full load displacement. In fact, I absolutely hate it.
    The idea of assigning ships units, is to help determine their relative fighting power when compared to another warship. The present system we use does this. The ships are where they "feel" right in relative combat power. The "cut off" points for the various units are set up with STANDARD displacement in mind. If we began to use FULL load displacement to determine units, we'll have to re-calculate all the unit cutoff points to get ships back to where they should be. If we don't, then all we have done is inflate the shiplist in an unequal manner, where some ships will benefit more then others.
  3. JKN
    JKN Member
    Not to dig up an old thread but why not have it by nummer and size of guns plus size of hull if need be?
    A couple of the locals here in Dayton were discussing something similar to that this year. But we never got past the discussions phase.
    There still seems to be interest in coming up with a better solution. But actually finding it seems harder than it might be expected.
  5. JKN
    JKN Member
    LIke say go with the Big gun fromat of gun calibers except make them equal from smallest to largest of the 4 size ball bearing chart range from 1/4 to1 unit for the guns and maby have the size of the hull or hull size and class for the pumps?
  6. DarrenScott
    I'll have a go here, even if I have no idea what I'm doing...
    Allocate gun units and pump units like this:
    Use figures only from Conways.
    Base gun units on (Number x size x caliber / 20) of main guns on the actual ship.
    ie: Bismarck had 8x 15" (rounded metric bores into inches) x 47cal = 8 x 15 x 47 /20 = 282 units. Result is then rounded down to nearest 25. Gives 275 units.
    This would give you four barrels @50 rounds each, and one @ 75 rounds, or any combination you feel would suit you.
    BTW, no half-unit guns for ships with four or more working barrels. Max rounds per gun to be 75.
    Base pump rates on (full load in tons / 200). Change last two digits of result to zeros. Gives outlet size in 1000ths of inches.
    ie: Bismarck was 50900 t (50900 / 200) = 254.4. change last two digits to zeros gives 250.0 thou = 1/4"
    I'll let you all crunch the numbers for the other ships, and see if i'm in the ballpark, or the carpark.
  7. mike5334
    I can do a lot with a 1/4" outlet. Heh.
  8. Chris Easterbrook
    If you read the acual washington treaty it will tell you the difference between standard and full displacements and full load does not reflect any additional combat ability. It is what a ship displaces with a full load of full ammo and a full crew plus the weight of ship, nothing more.
  9. JKN
    JKN Member
    Darren has a really good Idea,
    Go Aussey
  10. JKN
    JKN Member
    But I dont really agree with the pump part though I like the current by class gpm,
    How about haveing the (# of guns X diameter X caliber/ 1000)
    So then using bismark as example,
    (8x15x47/100=5.64 rounded is 5.5 units):
    or have it be (# of guns 3in over x there diameter/40 then rounded to nearest half unit)
    so then Uss Indiana (BB-1) as example,
    before 1908: (4x13)+(8x8)+(4x6)=140/40=3.5 units
    between 1908 and 1910: (4x13)+(8x8)=116/40=2.9=3 units
    after 1910: (4x13)+(8x8)+(12x3)=152/40=3.8=4 units
    and the units are overall and not just for the guns.
  11. DarrenScott
    Just did the figures for my ship, if she was fastgun, which she's not.
    HMS Rodney: 9 x 16" x 45cal
    Gives 9 x 16 x 45 / 20 = 324
    Rounds down to 300 units. (Makes sense as she was more heavily armed than Bismarck).
    Full load was 41250 ton as built (I use "as built" figures, so that ships that did not have long careers are not disadvantaged!)
    Gives (41250 / 200) = 206.25 rounded gives 200 thou for the pump outlet. (also makes sense she was less heavily armoured than Bismarck.)
    The pump calc should read "(full load in tons / 200), convert last full digit to zero, disregard numbers below 1 "
    JKN, and any others who wish to, could you do the numbers for your ships, please?
    I think the divisor for the pump calc may need tweaking.
  12. JKN
    JKN Member
    Well for the Indiana BB-1 I am building for treaty would be,
    arment wise, 4x13x35=1820/20=91=75 rounds or 1.5 current units! :(
    pump wise, (dont know full so Ill put standard) 10288/200=51.44x.001=.05 of an inch! :(
    current way I can have 3.5 overall units!
    3 for stern guns 2x75 and .5 for pump 1gpm
    :crying:
  13. DarrenScott
    That's what I was afraid of, the calc is too linear. Perhaps an absolute min of 3.0 units would compensate?
    However, Indiana BB-1 would hardly be expected to win a fight with even a WW2 cruiser, so perhaps the figures reflect that?
    A pump outlet minimum of 1/8" may suffice.
  14. JKN
    JKN Member
    I chose the Indiana so I could be small and maneuverable,
    In combat I would stay far from shore and let them come to me when they try to shoot my sides I turn giving them some serious stern gun love:)
  15. JKN
    JKN Member
    The founders of treaty said I could build it if I kept it just slow enough to get away from the slowest convoy:)
    Min warship speed, 22 knots
    Min convoy speed, 20 knots
    My speed, 21 knots.
    In a way it would be better in my opinion to have all guns 3in and over multiplied by its diameter divided by 40
    Because with overall units you can choose amount of defense and offense.
  16. DarrenScott
    Until you apply that to a Yamato, 12 x 6.1" 60cal, plus 12 x 5" 40cal, or Iowa, 20 x 5" 38cal.
    Ouch.
  17. DarrenScott
    Yamato. Better do the numbers for her.
    Guns:
    9 x 18" 45cal
    Gives 9 x 18 x 45 / 20 = 364.5
    Rounds down to 350 units
    Pump:
    69,990t full load.
    69990 / 200 = 349.95.
    After rounding, 340 thou pump outlet.
  18. JKN
    JKN Member
    ok yamto by mine would be,
    9x18 plus 12x6.1/40=162+73.2/40=235.2/40=5.88=6unts,darnwhere did I screw up at?
    Lets try this again,
    New idea,
    main x diameter plus secandary x diameter/30
    Indiana 13x4+8x8=116/30=3.86=4 units
    Yamato 9x18+12x6.1/30=162=73.2/30=235.2/30=7.84=8,
    yay it worked for those two:)
  19. rcengr
    Interesting way to calculate guns. It gives both my cruisers an extra 1/2 unit, and the destroyers are the same or less. The Gridley gets only 25 rounds, which makes it less attractive to build, but is probably fair. How would submarines and carriers be handled?
    Baltimore - 175 rounds
    Roanoke - 150 rounds
    Gridley - 25 rounds
    Gearing - 50 rounds
    Liberty ship - 9.5; so zero?
    I can't say I like any pump calculation that results in an orifice size. This gives an advantage to those that can create the highest pressure pump. And besides, testing so many orifices would require a large set of gages.
  20. DarrenScott
    Iowa.
    I'll just put the final numbers up.
    350 units for guns.
    280 thou pump outlet.
