US Liberty Ship
Discussion in 'Warship Builds' started by lockley, Nov 25, 2012.
  1. lockley
    lockley New Member
    Hello this is my first time on this website and I was thinking about building a liberty ship because it seems the easiest ship to build. Also this will be the first ship that I build. I have no clue how to start and I need help. Thanks for your help.
  2. joe thomer
    joe thomer Active Member
    the first ship I bought was a liberty ship, but it was already built. It gave me go buys on how to get started. are you building to use in battles or just to run around?
  3. lockley
    lockley New Member
    Both though I am not sure where the battles are around me, but I will cross that bridge when I come to it.
  4. jch72
    jch72 Active Member
    Are you in Massachusetts? There are a lot of really nice ircwcc guys in the northeast that will be glad to help you get started.
    Ron Hunt
  5. lockley
    lockley New Member
    No I am in Pennsylvania along the border of Maryland.
  6. lockley
    lockley New Member
    Ok so I found a few plans on a previous post but I still don't know how to make. The radio box to waterproof the electronics or. How to set any on the electronics up.
  7. lockley
    lockley New Member
    Also what should the with of the keel and ribs and where can I get the balsa wood cheap enough?
  8. gunsnrosesx
    gunsnrosesx Member
    worry about putting the hull together first then worry about electronics
  9. Knight4hire
    Knight4hire Active Member
    I hope that you are active with a local club.
    The thickness of the ribs depends on the size of your windows.
    Check with your club's rule set for the spacing and thickness of ribs.
    As for the keel, that does not matter much. Whatever you think is best, or whatever thickness of wood you happen to have on hand.
    An important item would be a block to insure that each rib is perpendicular to the keel and properly spaced.
  10. bsgkid117
    You're in the perfect spot. There are IRCWCC guys in every direction if you live at the PA/MD border.
    Check out the IRCWCC yahoo group, say hi, and keep eyes open for when everyone meets up again to build boats. Might learn some useful stuff, I know that as a rookie myself I have picked up a lot of great info from seeing other people's boats in various stages of construction.
