Usefull reloading tool
Discussion in 'Weapons & Pneumatics' started by GregMcFadden, Mar 24, 2007.
  1. GregMcFadden
    Well, I found an interesting little widget for reloading cannons that makes getting to those hard to reach magazines a bit easier. for bb and 3/16" ball bearing check out the dillon precision small primer pickup tube, part number 22028. simply heat the pickup end a bit and squeeze till it picks up bb's from your hand one at a time, then flip, line up, pull pin and the magazine is loaded. The small primer tube plastic pickup measures (before the heat and squeeze) about .180in diameter while the large primer tube's plastic widget measures about .220. both have a molded in lip so one can push the bb's past the inlet but if the diameter is correct, they can not get back out... I just started playing with it tonight, we'll see how she holds up.
    http://dillonprecision.com/template/p.cfm?maj=13&min=6&dyn=1&
    anyways, back to playing with cannons, as always your results may vary...
    -Greg
