Using a 3D printer
Discussion in 'Construction' started by donanton, Sep 19, 2007.
  1. donanton
    donanton Member
    Has anyone heard of anyone that has used a 3d printer to make the ribs and keel of their ship?
  2. Anachronus
    I think there are problems with the material that the printer puts out. I don't remember which but it was either heavy (bad) or water soluble (very bad)
  3. SnipeHunter
    actually i would think that the real reason not to do this is cost, that stuff isnt cheap. but ours uses ABS which can withstand a bb impact so you probably could do it. Its not super light wieght but it might not be that much heavier than exopy coated wood and at least the stuff we use isnt water soluble so you dont need to waterproof it, but its not waterproof either so as water gets in it the weight will increase, doesnt hurt the material just makes it heavier. but if you have access to a machine and material I think it would be worth trying, well if you didnt have to pay for it that is might be an interesting experiment.
  4. Anachronus
    I was getting my threads confused. I was thinking about the person who built a boat out of MDF and it sort of broke down when wet. I think the term used was dissolved.
    I can only imagine the machines are costly. Still if you used it for ribs and not superstructure you could get away with it. Mind you I am more of a destroyer/cruiser person so weight is an issue for me. Battleship captains have more lee way.
  5. donanton
    donanton Member
    MDF?!?! Did that guy know mdf is glued sawdust? Bad Idea.
  6. Anachronus
    Obviously not before hand. I personally avoid MDF like the plague.
  7. donanton
    donanton Member
    If someone was really slick, they'd have the ribs, keel, and other impenetrable areas (minus deck and superstructure) made in a 3d printer as one piece. They'd also have to find a 3d printer that could print something 5' long.
    It would be sweet though.
    I use only the finest tissue paper for the ships I make for James. Banzai!
  9. JustinScott
    JustinScott Well-Known Member
    MDF could work, IFF you seal it or fiberglass over it.... so that it will never get wet. But make sure the seal will not break when shot.
  10. Anachronus
    Yes..they are very light.
    j.
    [:D]
    HEY!!! New hobby idea! R/C Origami warships!
    [:p]
  11. Anachronus
    That it would.
  12. klibben
    klibben Member
    It's been done, well not in 5' but there was the capability. I never found out EXACTLY what he was using but an old friend of mine who used CNC mills and lathes designed and built his own machine that would make whatever he designed on the computer out of different types of material he put in it, such as resin or plastic.
    He was going to start doing ship kits this way, but sadly he passed away... i believe a little over a year ago.
    I have another friend who is slowly working towards that point, he is using a 5 axis cnc lathe/mill and we are working on a 1/96 BB-12 and BB-11
  13. Anachronus
    Sweet. Keep us posted on the progress.
  14. klibben
    klibben Member
    will do, actual progress hasn't really started as he is still testing out the machines and everything like that... so nothing to show for yet.
  15. SnipeHunter
    why couldn't you do it in sections and fit them together? we do that all the time at work.
  16. donanton
    donanton Member
    well of course you could do that
  17. Anachronus
    The joins would probably be stronger than the structure.
  18. donanton
    donanton Member
    I just gotta get some prices and material strengths to see if it's worth the price.
  19. donanton
    donanton Member
    Anyone know the force a pellet hits with at max psi?
  20. donanton
    donanton Member
    0.78J at legal pressure
    1.33J at max pressure
    paintballs hit with 11j. Just a small comparison.
    Numbers were compiled by snipehunter.
