USS Texas big gun build 3d
Discussion in 'Warship Builds' started by cwatts, Nov 28, 2025.
  1. cwatts
    cwatts Member
    mn
    Some photos of my USS Texas
    Fully 3d printed, cannons included.
    JustinScott and Xanthar like this.
  2. JustinScott
    JustinScott Well-Known Member
    Making progress! Looking good!
    cwatts likes this.
  3. Kotori87
    do you intend to arm the amidships turret?
    cwatts likes this.
  4. cwatts
    cwatts Member
    mn
    Yes I do, it is on a servo for targeting same with all 4 other turrets.
  5. mabgfounder
    mabgfounder Member
    Salem, Virginia
    Thanks for sharing your progress! Looking great so far!
  6. cwatts
    cwatts Member
    mn
    I have been working through the electrical and pneumatic stuff for the last week or so. I have a functional targeting system and trigger system is working also.
    I have sanded down the layer lines and put a thin layer of paint that bonds to the plastic well into the hull. Working on sheeting the sides and getting the paint started.
    Wmemlo likes this.
  7. JustinScott
    Love it!
  8. cwatts
    cwatts Member
    mn
    Getting the balsa to bend around the stern of this thing seems to be quite an undertaking. Any tips?
  9. mabgfounder
    mabgfounder Member
    Salem, Virginia
    I soak the balsa in Windex for about an hour first. Be careful to get the og Windex - it is the ammonia that breaks down the wood fiber strength.
    cwatts likes this.
  10. Kotori87
    get good balsa. Softer balsa is better at curving around those tight bends. I've seen a few people try soaking in windex, but I wouldn't recommend it. The balsa becomes brittle afterwards, and chunks badly when hit.
    When I'm balsa shopping, I test every single sheet at the hobby shop and only pick a few of the softest sheets. When ordering online, I order the lightest density I can get, ideally competition-grade. The quality makes a difference.
  11. cwatts
    cwatts Member
    mn
    Well... There is wood on it haha. This process will take some practice for sure. I set the balsa over gorilla tape like Justin suggests so I can rip this off quick and do it again when I get tired of how ugly it is.
    Thanks for the tips on bending this stuff!!
  12. JustinScott
    Honestly, that looks pretty damn good to me!
  13. cwatts
    cwatts Member
    mn
    Thanks, I took the picture of the good side.
    JustinScott likes this.
  14. cwatts
    cwatts Member
    mn
    A little primer after a quick sand. Not to self, 60 grit versus balsa, just a touch more aggressive than required.
  15. cwatts
    cwatts Member
    mn
    A small splash of paint and finally a pressurized and holding pneumatic system.
    This regulator tested at 155-158 on my Chinese gauges. Close enough?
