V shaped Hulls
Discussion in 'Construction' started by wfirebaugh, May 2, 2014.
  1. wfirebaugh
    wfirebaugh Well-Known Member
    El Paso Texas, USA
    Can any one name a few countries and names of ships for examples that used V shaped hulls? I was wanting to do some research over the hulls and see what classes of ships if it wear a battle ships or cruisers or destroyers. not much was turning op in Yahoo/Google searches :).
  2. irnuke
    "V" hulls (very deep keels) are needed for ships with VERY large tendencies to move w/ the wind (ie drift). Namely, sailing ships. Since they are narrow & deep, in order to get greater displacement for a larger ship, you either have to go very long and narrow, or have a hugely deep draft. So, you won't find anything modern (or even steamships ~1850's) with this shape
  3. wfirebaugh
    El Paso Texas, USA
    Ok thank you :) that anserd the Q.
  4. irnuke
    About the closest you'll find would be a Destroyer. Very narrow beam for length. Even they had rounded or flat bottoms for much of their length, though
