Vector
Discussion in 'Vendor News' started by Charley, Jan 29, 2017.
  1. Charley
    Charley Vendor
    Lancing, Tennessee
    Captain's we would like to share our latest Combat Gear design "VECTOR" to gather interest for production. You will find that this would greatly reduce components and complexities of our ships. These are not in production as of yet. "Estimated" street price for assembly only $60.00 No magazine or up tube those would be sold assembled separately as a complete cannon (price to be determined).
  2. Charley
    Charley Vendor
    Lancing, Tennessee
    To give an example of size pic noted in mm or 1-5/8"
    skull not included :) just me tinkering. The blue solenoid coil assembly is standard from the BC solenoid
  3. ish311
    ish311 Active Member
    North Central Florida
    that looks really nice
  4. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    Interesting. Does it share the same parts as the current cannons? Is there are rivet and a spring in there?
    Would one run a line from one of those ports to the end of the magazine?
    Could we see a mock up of the entire assembly?
  5. Charley
    Charley Vendor
    Lancing, Tennessee
    There is a custom piston and spring inside similar to what is used now in Tee's
    There is an #10-32 supply port and a #10-32 Magazine port
  6. NickMyers
    so it doesnt come with the solenoid or the rest of the gun guts? its just a fancy T that the solenoid can screw directly into?
  7. Charley
    Charley Vendor
    Lancing, Tennessee
    Yes its a Solenoid and interrupter assembly in 1
  8. NickMyers
    So just to confirm
    Vector assembly is just the block pictured, with interrupter built in, solenoid valve seat builtin, and o-ring sealed brass collets for mag and uptube connections.
    After which the builder needs to supply magazine, solenoid, uptube, breech and barrel.
    Whats the width? Plausible to use in twins or triples configurations?
  9. Charley
    Charley Vendor
    Lancing, Tennessee
    BC will also offer it as a complete cannon as well as a complete Solenoid/interrupter assembly. (You add up tube and mag assemblies.)
    Max width 27mm so it will be quite easy to form in a dual/triple configuration
  10. Lou
    Attachment point to the blocks so they can be connected together?
  11. Charley
    Charley Vendor
    Lancing, Tennessee
    Yes there are 2 M2.5 holes seen near the input port for fixed mounting. Also a 1/4" through hole and notch for swing arm style so you can build an adjustable or gyro stabilized elevation devise.
  12. Lou
    Did you get enough interest to proceed?
  13. Charley
    Charley Vendor
    Lancing, Tennessee
    No not many spoke on it
