Water Channeling epoxy?
Discussion in 'General' started by MasterClay, Nov 25, 2011.
  1. MasterClay
    MasterClay Active Member
    morris, illinois
    I'm looking for some sort of self leveling epoxy to use for my water channeling in my boats. what works good? and where can i get it?
    Thanks, Jason
  2. daemond6
    daemond6 Member
    Self-leveling cement filler seems to be the one of choice, just GoogleShop search it, and you can sort by proximity and price.
  3. Bob
    There's one brand on the self leveling concrete sealer that's better than the other. Don't ask me which one I don't use it. Becareful on a ship that is close on weight, that stuff can get heavy.
    I use a two part plastic with micro ballons. It's light and will even float. a little foam CA glued to the hull then pour plastic over it.
  4. MasterClay
    morris, illinois
    i'm not even close to weight its on my carrier that i'm using for convoy
  5. mike5334
    PL is the name of the good stuff. Available in Lowes and probably Home Depot. It must say self leveling concrete crack sealer.
  6. MasterClay
    morris, illinois
    thanks everyone
  7. NickMyers
    This is what you want
  8. Kotori87
    Cement filler works fine as a water channeling material, but it just doesn't look as good as epoxy if you've got a beautifully built wooden hull. I put a lot of effort into my wooden hulls, so I use Tap Plastics marine grade epoxy for my water channels. It's a lot more expensive than the cement filler, but I pay the extra because it shows off my woodwork better. If you've got a fiberglass hull, budgetary limitations, or construction errors that you want to cover up, then go for the cement filler instead.
  9. MasterClay
    morris, illinois
    Thanks alot, i went and picked up a few tubes of the PL stuff today
  10. mike5334
    Make sure you seal the bottom edges of the water channel before using the PL else the stuff will seep under and into the water channel.
  11. MasterClay
    morris, illinois
    thanks for the tip Mike
