Waterline Marking
Discussion in 'Construction' started by tgalx3, Jun 11, 2022.
  1. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    What is the best way to mark where the water line is on a new build? Measure from the top of the hull to the water?
  2. Commodore
    Commodore Well-Known Member
    Sunny TX
    If you're using a fiberglass hull, put the desired amount of weight in it and put it in a bathtub, swimming pool, etc. and see where the waterline wants to be. Mark it with a pencil/crayon/etc. Don't eat the crayon. (Joke intended for someone who probably won't see this).
    But yeah, things don't always work out according to the plans, it's best to see how it looks in the water.
    Boatmeister and Nibbles1 like this.
  3. tgalx3
    Snohomish, WA
    I find the eating of crayons to add to the ship building experience.
    Beaver and Nibbles1 like this.
  4. bmarkb
    bmarkb Active Member
    Hampton, VA
    Tape a Sharpie (or whatever) to a block measured to the draft of the boat. Keeping the boat and block flat on a table, move the Sharpie around the hull to mark the waterline.
  5. LjWolf303
    LjWolf303 Active Member
    Payson, UT
    What’s the draft of the boat?
  6. tgalx3
    Snohomish, WA
    It’s where the waterline is when the ship is at combat weight. You can get the weight range from the IRCWCC ship list.
  7. Nomercy
    Nomercy Well-Known Member
    Maryland
    Mark in front and back. Chalk line. Straight every time.
  8. BigGunJeff
    BigGunJeff Well-Known Member
    I like to use one of the self-leveling laser levels on a tripod. Put your boat on a flat table, line up the laser level with the waterline, and paint to the laser line. I used to use thin masking tape and a reference on the bow and stern, but I found that it would vary too much while applying the tape.
    Z Boat likes this.
