Wax
Discussion in 'General' started by JustinScott, Jan 15, 2009.
  1. JustinScott
    JustinScott Well-Known Member
    Soooo... where do I buy wax? For testing my mill on stuff that I can melt back into a brick.
    Candle wax? Can I just go to discount stores & buy a whole bunch of discounted candles?
  2. GregMcFadden
    You should really look at machinists wax. use-enco.com or http://www.freemansupply.com/
    if you search on www.cnczone.com there should be instructions for making your own.
  3. JustinScott
    So freeman wax seems to be for creating molds with loss-less quality. Not really what I'm going for, is it? I want to rough cut cheap re-usable material until I have all the details worked out, then cut it out of metal.
    Is there a reason regular wax won't work? Is there something freeman wax gives me extra?
  4. GregMcFadden
    machinists wax (freeman makes many types for many different uses) is harder, and will cut cleanly. Regular candle wax is much softer and gummier, meaning you run a higher risk of melting it to the bit when not cutting at proepr speeds and feeds (and even sometimes if you are) as well as the worse tolerances you will get.
    the best rough cheap material is pink foam from home depot. not reusable, but holds tolerances well and is as forgiving as it gets. dusty though, clean the ways and screws often.
  5. RiverRaider
    RiverRaider Member
    Wisconsin
    Hello,
    In addition to what Greg said you can also use parts
    made from machinist wax for masters for rubber molds.
    After you use machinist wax the first time you will ask
    yourself how you lived with out it before. I use a small
    vac to catch all the wax as it comes off the cutter to
    reduce loss. I bough mine through the Tech college years
    ago and still have over half of what I started with.
    Chuck
