Wood Built with bulge in scale position in (Built in 2003) features with 3/16 and 1/4" ribs with 1/8" main deck panels and is slide lock design(no hold down screws), All in Aircraft grade ply not Baltic. Deck rim shows combat usage. Balsa water channel and hull bottom fiber glassed with heavy grade mat so nice and strong all sealed with West Systems. 02 deck and above are molded FG superstructure. Interior is is great condition. Included is drive system, Bilge pump, All 5 accumulators with fittings. Leaving electronics in the drive box so you get Team Delta firing boards, Team Delta Pump switch. I removed the old Mag trottle Team Delta switches and added an ESC. Leaving the Cannons also they are modified by me and feature Stainless Steel Breech elbows with my Common BC Breech.I will also leave the tuned Williams Regulator used in the ship. Everything is built modular so you can completely remove everything out of the hull within minutes. Too many things to list...... Just replace hull skin add solenoids(also maybe a few co2 fitting) and rudder servo then she is ready to battle Selling for $700
A fine looking ship. Love the on the triples. Someone is going to be a happy buyer, whoever they are.
Where would I get these and how would I install them?replace hull skin add solenoids(also maybe a few co2 fitting) and rudder servo .(I'm a beginner)
You can order the parts through Charleys company " Battlers Connection" online and they will send you the parts. As far as assembly if you can get with someone local to you, get together for a battle,build and bull session. I believe Rc'nut lives out your way. I invited you and Nut to a conversation so you can talk to him there.
I would be willing to help you with whatever construction help you need, however I don't have a shop anymore so I've been doing most of my building in Ohio, lol.
As the seller owns BC, I am sure he would negotiate a price to set it up with guns and connections for you. Call him and find out.
I do believe that Mcspuds already has purchased this and its battling with the other fine family of ships he brings to the water.
