2 quick questions?
Discussion in 'General' started by uss Johnston 557, Apr 22, 2013.
  1. uss Johnston 557
    uss Johnston 557 Member
    2 quick questions,
    1. what type of bb gun should i use for a Fletcher class destroyer.?
    2. can i buy them some were or do i have to build them myself.?
    Buy one from Strike Models or Battler's Connection. They take Paypal and it's easy. To answer #2, you CAN build your own, but that doesn't mean it's a good idea. Buying one means that it'll work and you won't go to battle with a gun that leaks or jams up or spurts. One cannon costs like $35 or so, and it's easily worth that in terms of saving yourself stress and build time.
  3. uss Johnston 557
    Can i use any type of gun for a destroyer?
  4. MasterClay
    MasterClay Active Member
    morris, illinois
    no you will need to follow the rule set for the club in your area
  5. uss Johnston 557
    Can you buy 1/4 inch torpedo guns anywhere ?
  6. Kotori87
    No. Those you would have to make yourself. However, single-barrel torpedoes can be made using fairly simple tools to slightly modify a bunch of off-the-shelf parts. What ruleset are you building for?
  7. uss Johnston 557
    Big gun ntxbg
