3D Malaya
Discussion in 'Warship Builds' started by Lou, Aug 16, 2023.
  1. Kevin P.
    Looks great lou, I need to build mine
    for batteries, goldbat 3s LiPos on Amazon, many different options for C rating and capacity, I ended up with the 6000 mah 55c ones
    Panzer and Lou like this.
  2. bsgkid117
    Kevin, the hull kits have come a long way from that alpha version you have. If you wanted a replacement, up to date model, let me know. Per alpha tester rules, you are entitled to an up-to-date hull.
  3. Lou
    Will update soon, the modified motor mounts are on their way from sendcutsend.
  4. Lou
    Batteries ordered, Black Friday sales started today.
    Zeee 3S Lipo Battery 5200mAh 11.1V 80C with XT60 Connector Hard Case Battery for RC Car Truck Tank Boat RC Plane Airplane Quadcopter Helicopter (2 Pack)
  5. Lou
    Anyone know how to tell if a BC solenoid is 6 or 12 volt? I did order and receive them last year, not sure in my stash which is which.
  6. bsgkid117
    Take the top nut off and pull the silver cover off the coil. The voltage should be written on the coil, at least on most of mine it is.
    Lou likes this.
  7. Commodore
    Commodore Well-Known Member
    Sunny TX
    The BC solenoids are 6V
  8. Lou
    Ok to run 11.2 volts through them?
    I did look at the solenoids, all except one were labeled 6. One had 12 (and I swear I ordered 4 of them). Of course they could be stashed somewhere in the shop...
  9. Kevin P.
    I run all my solenoids at 2x nominal voltage
    Lou likes this.
  10. Lou
    Gorilla tape on outside
    Going to do the steps backwards, will complete the hull and then figure out where all the internals want to go.
    vicious p likes this.
  11. Lou
    Back to the build. Trying to get a pump to fit under the step, first order of business is to cut out the bottom (this also removed the previous failed attempt).
    Test hull plate created
    Holder V2, this gets bolted to the bottom of the hull (stays in the ship)
    SJS 45 pump that slides into the holder
    Removable screen (1/8th hole size)
    Ok, the next issue is the bend in the 3/8th (ID) tubing, was kinking so I need to find a different version. Went to McMaster-Carr and have a few to try out
    Anvil_x likes this.
  12. Anvil_x
    great work on the screen there, Lou!
  13. bsgkid117
    I want to add for the audience, Lou's hull is a very early production hull that is a one-off belt drive modification. Normal SJS Malaya kits have a designated pump outlet location in the deck rim after the deck step.
  14. Lou
  15. Lou
  16. Lou
  17. Lou
  18. Lou
    IMG_1222.jpeg Battery holder
    groove for water to drain
    holes to go into water channel
  19. Commodore
    Sunny TX
    Oh, that battery box is kewt!
  20. Anvil_x
    Oh Lou, you're making me want to go back and reconfigure the battery bay on my project a bit. that's nice!
