3d printer
Discussion in 'Digital Design and Fabrication' started by Captain obvious, Oct 6, 2016.
  1. Captain obvious
    Captain obvious Active Member
    Hastings, MI
    What 3d printers does everyone use and what are the pros and cons of each one. Looking at getting one and would like everyones impute. Don't have thousands to spend though.
  2. NickMyers
  3. Beaver
    The printer Nick linked to is probably your best bet. I bought a cheaper i3 and it's needed a lot of fixing over the last couple months.
  4. absolutek
    Which one did you get @Beaver ? Just so others can avoid it.
    I'm building a Rostock Max v3 at the moment. Could be another option (though I can't vouch for how good it is until I've actually used it to print for a while).
    https://www.seemecnc.com/collection...cts/rostock-max-v3-desktop-3d-printer-diy-kit
  5. Charley
    Charley Vendor
    Lancing, Tennessee
    I have this one and it has been flawless in operation. Large print bed enclosed, dual extruder
  6. Xanthar
    Xanthar Well-Known Member
    Upstate NY
  7. Beaver
  8. Beaver
  9. NickMyers
    Get the igus bearings. Find the ones you need and ask for a sample. Soooo nice
  10. Beaver
    Haha, feel like I'm cheating them. Lol Sent an inquiry. I'll see what I end up with. Thanks, Nick.
  11. absolutek
    Wow, sounds like you've replaced most of the printer already.
  12. Beaver
    Yup, eventually I'm going to have to replace the frame too. Acrylic is too brittle for a 3D printer frame. Mine has a few cracks in it already.
  13. NickMyers
    Buy the replacement soon as you can. That cracked acrylic will fail at a really annoying time.
    I had to ask Greg to machine me some replacement pieces out of abs for my ormerod since its sort of an oddball printer.
  14. Beaver
    Yeah, I'm thinking about getting a wood frame. I would like a steel one, but their sooo expensive. :(
  15. NickMyers
    Look into using 80/20 aluminium extrusion. Might be a good middle of the road solution.
  16. Beaver
    That's a thought. :)
  17. ish311
    ish311 Active Member
    North Central Florida
    my max v2 is really nice when it would callibrate and sofar the new head is solving that problem. same head as the v3 kit
  18. absolutek
    The v3 is also easier to put together than the v2 from what I have read. They replaced some of the melamine pieces that were causing issues with injection molded pieces, not sure what else. The assembly instructions are pretty good to.
  19. Beaver
    Been a while now and didn't get anything...:(
  20. NickMyers
    Hrm, I got a same-day response.
