Looking For 3D printer
Discussion in 'Buy, Sell and Trade' started by Keithintn, Mar 4, 2020.
  1. Keithintn
    Keithintn Member
    Memphis
    Is there someone here that can print a Brooklyn superstructure for me.
  2. bsgkid117
    I can. Just a big warning. Brooklyn is a light boat. Any 3d printed superstructure I could make for you will either be heavy, or be fragile. If you give me your preferred settings and the files you are using, I am sure we could work something out.
  3. Keithintn
    Keithintn Member
    Memphis
    I only build static, I`m a disabled vet and I don't get out much. So fragile should be ok.
    The superstructure by rcengr on this site. Not sure if you can download and print or if I can send to you. Let me know what you can do. I appreciate what you can do.
    Many thanks,Keith Anderson
  4. bsgkid117
    I will download the files and look them over. If you only build static, you may want more detail than I can really provide. My printer is calibrated for larger layer lines and extrusion widths, meaning big parts fast. Not necessarily the best at high detail.
    I'll let you know what I can do.
  5. Keithintn
    Keithintn Member
    Memphis
    See what you can do and we can go from there. I can add intricate detail.
    Regards, Keith
  6. Mad_Modeller
    Mad_Modeller Active Member
    Edmonton, Alberta Canada
  7. Mad_Modeller
    He is willing to change the scale if you send him a email thru the site.
  8. Keithintn
    Keithintn Member
    Memphis
    Thanks,used him for my Massachusetts superstructure. Nice work but $$$$$.
