[3DP]MAXi Brushless Battleship Pump
Discussion in 'Construction' started by Beaver, Aug 21, 2016.
  1. NickMyers
    you might want to also consider changing your discharge so instead of running into a wall and then going up you have internal geometry more akin to a curve. Not sure of your software package, but basically look to sweep a circle along a smooth curve to make your 90
  2. Beaver
    Yeah, I had wanted to do that when I first designed this. Couldn't figure out how to do it then. I think I know how to do it now. Stay tuned for v2. :)
  3. Beaver
    Long time coming, but v2 is in the works. Did a complete redesign, but the results are so much better.
  4. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    Looks good! How does it pump?
  5. Beaver
    Pumps like a pump. ;) GPM haven't been tested since the discharge isn't done yet. I should have that wrapped up here soon though.
  6. NickMyers
    A definite improvement in body design. Interesting volute design.
    There's a reason mine has the lip at the join between motor mount plate and volute... :)
  8. LjWolf303
    LjWolf303 Active Member
    Payson, UT
    How does one get a pump?
  9. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    SJS has them.
    LjWolf303 likes this.
