Looking For 4 blade 1.25 props
Discussion in 'Buy, Sell and Trade' started by wdodge0912, Jul 22, 2022.
  1. wdodge0912
    wdodge0912 Well-Known Member
    Doesn't matter
    Looking for 2 sets (left and right) of 1.25 (inch and a quarter) props. just seeing what is out there before ordering new from somewhere
  2. Xanthar
    Xanthar Well-Known Member
    Upstate NY
  3. wdodge0912
    Doesn't matter
  4. Xanthar
    Upstate NY
  5. wdodge0912
    Doesn't matter
    while they are great props (had one on the Baden I had) at 31.35 a prop, it's a little expensive to be dropping for 4 props on ships that haven't hit the water yet. I probably will order them in plastic soon so I can get the shafts fitted, but still want metal before they get into combat action.
    Also, I'm just seeing if anyone has some spares they want to /could part with before I go get new.
  6. Commodore
    Commodore Well-Known Member
    Sunny TX
    Just order two for the main shafts, and use 3d printed or other less valuable props for the decoratives. No sense using the good stuff on props that are not going to be used, or are just going to be damaged/lost.
    Heh. If I remember later, I'll post some hokey drag "prop"/disc things I cooked up for someone else's Seydlitz a while back. They're hokey, but they will do, and they don't cost $30 each.
  7. wdodge0912
    Doesn't matter
    It's actually for 2 different ships, and both are just 2 shaft ships as well.
  8. Kotori87
    Best to start with basic 3d printed props, then, and figure out what works.
  9. Iunnrais
    Iunnrais Active Member
    Texas
    Considering how well they have held up, I don't think that I'd call them hokey at all.
