Discussion in 'General' started by A77l, Jun 7, 2009.
  1. A77l
    A77l Member
    hey my where my rudder,and propeller comes in though holes, and those holes are letting water in and i don't want that.how do i stop it from leaking
  2. Kotori87
    The trick to sealing rudder posts and prop shafts is to use a stuffing tube. A stuffing tube is a brass or stainless-steel tube that the prop-shaft or rudder post goes through, that you fill with grease or oil to prevent water from entering. These are commonly constructed from K&S Brass tubing available at your local hobby store, or from the stainless steel tubing located in the same section.
