6 VDC vs 12 VDC?
Discussion in 'Electrical & Radio' started by Jay Jennings, Feb 7, 2019.
  1. Jay Jennings
    Hi all,
    What does everyone think the Pros v Cons are for both voltages.
    It was suggested to me that I should try 12 V, but I don't know of any advantages other that battery duration that would improve. Everything I have is 6 V but it is all usable in a 12 V system.
    I didn't see a thread with this comparison and I am curious,
    Thanks,
  2. thegeek
    12 volts. Kind of why Europe runs 220 and in the states 117. I owned a 6 volt vw once and that was a wonderful lesson.
  3. djranier
    Or run 10 v. I running 3 of the LifeP04 in series, gives right around 10 volts. The early brushless controllers did not like 6v much, had a habit of losing sync with the receiver.
  4. Jay Jennings
    Thanks Ming and DJ,
    But what are the advantages? Why increase from 6? and should I? This is what I am trying to determine.
  5. thegeek
    Higher headroom. Less amps for the same watts . tons of reasons.
  6. thegeek
    You can run a full sortie with two lipofe batteries 4200 ma 4 cells (14 volts) . recharge from your car and battle the whole day on 4 batteries.
  7. Litch42f
    Litch42f Well-Known Member
    Nevada
    Higher rpm for your bilge pump
  8. Jay Jennings
    OK, that is what I am looking for. I gotta say I am a bit surprised it makes such a difference, but I have only ever used 6V 12Ah SLA so I have nothing to compare it to.
    What does 12 V do to a stinger motor driven pump? It doesn't drain the pond does it? cause that would kinda be crappy ;)
    Thanks again,
  9. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    Personally something I like about 12v. is the fast acting 12v gun solinoids. They are cheap found them on eBay for less then 5.00$$$. Yes they are made in China but they get the job done. As for the stinger pump motor I bought one for testing 20$. I paired it with a BC pump housing ran it at 12v long story short it didn’t make it. Did it pump oh ya but The stinger couldn’t hang . I believe money well spent is on the Johnson’s 550 cheap and effective at 12v and you can have a few spares for what one stinger cost
  10. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    I hope you pressure tested these well...at 150 psi...I have found most of these from ebay may work a couple of times then they leak or stick.
  11. ZARUBA1987
    Tarkington Tx
    Absolutely. Sometimes you get whatl you pay for. So far I haven’t had a problem when testing they cycle as they should
  12. Kevin P.
    I wouldn’t be confident about the lifespan of a Johnson 600 on 12V, I toasted some pretty quickly. There are several mabuchi variants that are good at 12v, believe rpm is 16 - 19k range no load
