Agincourt build (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Sep 10, 2017.
  1. Kevin P.
    Rudder post installed, used resin from one of the hulls, perfect timing on a batch of resin about to kick
    Started on subdeck, had to push the top of the hull outward
    Traced around inside edge, 1/4” ply
    Position of the cross brace is not ideal, but I think it is the best option to allow access to the gearbox fasteners, will be over the motors but they will have a spin guard on them anyways
    Cut out for the pumps
    Glued in last night
    Traced out for the deck to reduce the number of tweaks needed
    Set pretty good, hardest step is done (for the stern)
    Bow subdeck
    Bow subdeck rough cut, still need to dremeling the bow area
  2. SteveT44
    I'm impressed Kevin. I count at least six hulls in this little corner of your work area!
  3. djranier
    The DD came out very nice looking also.
  4. Anvil_x
    every time I look at the plans for that ship, I wonder whether the naval architect that came up with the idea to make it a floating pile of gun turrets had a suitably absurd name to match his insatiable desire for the dreadnought version of more cowbell.
    lookin good so far, that subdeck is pretty sweet
  5. SteveT44
    She was designed and built for Brazil. The Brazilians' wanted an especially impressive design.
  6. Anvil_x
    yeah, I read up on that a while back. super interesting story. guess they wanted something with more firepower than the two dreadnoughts they had, but didn't want to transition to 14 inch guns, so they just added another turret!
    But could you imagine the architect that was given those instructions, worried his hands together with a grin and said "GIVE ME ALL THE GUN TURRETS!!!"?
  7. Kevin P.
    Yes Steve, I think I might have a problem haha. There are actually 7 visible in that shot, the bottom of the DE is barely visible (and really small)
    I got the forward sub deck and the deck rim over the past few days
    Here is the obligatory ‘look at all the clamps’ shot
    I used small blocks to help set the height, the forward deck and subdeck are 3/16” each
    Post drying,
    cut out the deck rim and test fit in place
    Stern. I used on continuous cut around the rim to allow the inner pieces to become the deck pieces, so an efficient use of materials
    More clamps, much easier set since the subdeck is in place
    Here are the deck pieces. I left some extra material to serve as the deck just aft of the set down, it will be cut to size once I see how the pieces fit in once everything is dry
    Deck pieces almost in place, I will have to trim them down to account for the rim shifting in slightly
    I’ll be taking the next week off while I travel home for the holidays, but the plan is to go full throttle once I get back. I always view the deck install as the transition from the project just being a hull to being a ship, so I’m glad that I got it in place
    SteveT44 likes this.
  8. Kevin P.
    Back to work over the past few days
    Cut the deck pieces down
    Bow
    Marked the deck to cut to size
    Underside of pump outlets, it will hold the tube and reducer direct from the pump
    Glued in the tubes and filled in the edge between deck and hull
    Holding down the tubes
    A lot of filler in the bow
    Dries the next morning
    Bow
    Cut out barb holes
    Dremeled down the excess
    Cut the tubes flush
    Drilled holes for magnets
    Aft piece
    Pressed in the magnets with pliers, tight fit
    Epoxy coat over the deck rim went on thick and smooth probably due to the cold temperatures
    Cut out the barbs
    Extra piece on the underside for the aft piece to support the 4 guns
    Under
    Worked on the mid piece
    Underside
    Tested out a few arrangements inside
    Bow
    Waterchannel tomorrow hopefully
    Renodemona, SteveT44 and Beaver like this.
  9. Kevin P.
    Worked on the waterchannel today, standard 1/4” balsa
    Also finished the rudder servo mount, using sprocket and chain from servo city
    Underside, 1/8 ply with 1/4 balsa sticks to help hold it together
    Aft waterchannel walls, the areas aft will be filled by micro bubbles and balsa chunks. This will form a platform to both keep water out of the extre stern and serve as a mounting point for the four aft solenoids
  10. Anvil_x
    Hey, those pump outlets look pretty sharp! how much thrust are you planning on gaining from them? lol
  11. Kevin P.
    Hopefully minimal thrust haha
    Finished waterchannel and a few other things
    Here is rudder servo with sprocket test fit
    Covered waterchannel with 1 layer of cloth and polyester resin
    Didn’t come out as nice as I hoped
    Filled the aft part in
    Dry
    Bottle holder
    Aft solenoids test fit and T clearance
    Bow side mount T clearance
    Filled bow void with foam
  12. Sinkazuki
    Sinkazuki Active Member
    Colorado
    Is it coming to nats?
    It's nice to see different ships.
  13. Kevin P.
    If I can make it to NATS I will bring it along at least. I'll see how it does in the spring battles, but I've also put a lot of work into the Missouri which would be my default ship depending how the sides end up.
    NATS this year might end up on the one week all year that I can't make it, I have an international trip with school around that same time period that might conflict I should find out around April
  14. Kevin P.
    Been a bit since I posted, Here was the last portion of waterchannel, wall in the front, came out good
    Gun parts shipment came in (for this boat and others planned). I used Blackhawk Supply, very low cost, quality looks solid as well
    Popped a motor in for getting the pump mounts in the right place
    General pump arrangement, same as Missouri
    Showing pump outlet hose route, nice large radius bend up and out
    Tested out the weight, I think it came out to 22.5 to 23 lbs, so I will have to pay attention to weight but should be alright (max 26.5)
    Arrangement check, feeling good about this configuration
    Batteries in the bow will be for drive, keeping them outboard gives room for CO2 hoses off the reg
    Solenoid mounts, 1/8" ply
    aft solenoids
    forward, squeezed in next to bottle
    They might be glued in in this picture
    pump mounts, same as I have used in the past
    Pump mount holes
    one pump. new BC large pump, the reduced width helped here
    two pump
    worked on guns
    up tubes and elbows, Foster breech, back feed, five for this boat
    magazine construction
    end caps. coupled with drilled pistons I have found that the CO2 entering through the bottom of the cap increases shot velocity.
    All the parts for guns
  15. Renodemona
    Nice! All those turrets in the back. Slug it out. pew pew. ;)
  16. Lou
    RRRRRRRRRAAAAAAAAAAAAAAANNNNNNNNNNDDDDDDDDDDDDDDDYYYYYYYYYYYYYYYY!!!!!!!!!!!!!!!!!!!!!!!
  17. Anvil_x
    Rad! can't wait to see the next post!
  18. Kevin P.
    Thanks guys, with 3 aft turrets I just have to use them all. I typically have high hopes for my boats, results vary haha.
    Did some work on getting the guns in, but primarily focused on other builds this past week. I knew getting the 4 mags in back aft would be a challenge. Started with the stern guns, pretty standard mounting. In general I make little magazine anchor points out of 1/8 wood and use wire ties to attach the guns, pretty simple and easy to make
    Now I started snaking the sidemounts in. A shot under the deck. Stern T’s are clear of aft-most solenoid
    The starboard sidemount snaked in. I had to curve it to reduce the length enough so it wouldn’t reach the rudder servo
    Overhead with all aft guns
    Another under deck
    Moving aft. The outboard solenoids will be do the aft guns, 1/4 pipe nipple and check valve, heavier than I expected but should be OK, they can be replaced to something lighter if necessary
    How is this for compact mounting? Getting the 75 rounder in was the toughest part, there are guns completely intertwined at some points. I use magnets on the Ts so I don’t need to worry about feed angle
    Under deck, less clearance than I expected, but there should be enough for a nice ‘unpersuaded’ deck placement. Showing the one mag cap I had to bend to clear the solenoid
    Bow was a bit simpler haha
    Still need to trim the up tube
    This build is coming along. Next big step is probably epoxying the deck pieces, making the base of superstructure, then maybe internal armor? I need to make a turret mold too, didn’t get to it this weekend, will need to mold 7 turrets
    Renodemona likes this.
  19. Lou
    You like some pasta with that stern?!
  20. daisycutter
    daisycutter Active Member
    Lou sign up for the Bruhadahahadaha.
    I love you xoxo
