Agincourt build (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Sep 10, 2017.
  1. Kevin P.
    I put them slightly below center, opposite the magazine. I use large magnets, others use the 5/16 diameter ones, the 1/2” ones have worked better for me with my hose configuration. I put them below center so they don’t ‘pull’ the bbs up which can cause double shots
    I use ca to stick them on then coat with goop
  2. Anvil_x
    Cool beans, thanks for the help! Any tips on getting down angle with these things? should I bend the neck a tad?
  3. Kevin P.
    Yes you can bend the neck/up tube.
    If you have strike guns i'm assuming that they are soldered together, but in the future if you use compression fittings then you can rotate the parts, so I usually will rotate the T slightly to get the down angle I need (I have the barrel perpendicular(ish) to the magazine (when viewed from above), so if you rotate the T the barrel elevation changes). I typically try to get the elbow and breech nut as close to the edge of the barbette as possible which typically gives the best down angle on sidemounts
  4. Anvil_x
    Okay cool. Yeah they're strike guns and soldered together. I'm already thinking about hitting them with my soldering iron to allow me to manipulate them in that way, so it's good to know I'm not a madman. I figure I'll give them a good solid look before loosening the solder and get them to a point where I can mount them.
  5. Kevin P.
    Started working on this project on the snow day today. Focused on the aft battery mounts. 4x headway 15Ah cells for the pumps. They just fit across the bottom, goal was to fill in the gap outboard.
    Also put on the float mount points, four 10-24 bolts through the bottom
    Aft ones outboard of pump mounts, the four are centered around the center of gravity
    Epoxied in the mounts, used a layer of cloth for wear resistant
    WillCover and Beaver like this.
  6. Kevin P.
    Small steps today. I put the rudder servo in the other day.
    I put the connectors on the solenoids and put them in the boat
    The stern gun accumulation tanks are 1/4 npt pipe nipples, along with the 1/4 npt check valves. These are heavier than I expected, but the boat should be able to take it
    I wrestled the aft guns into place
    View with barrels installed. They will be adjusted slightly, but they are generally where they should end up
    Plan is to sheet the boat this weekend, then maybe get some wiring done
    Sethie likes this.
  7. djranier
    Kevin, will that forward gun clear the pump outlet flow?
  8. Kevin P.
    Yes the pump trajectory is pretty low, so the forward gun should clear it. The port side sidemount might be in the path so I’ll keep an eye on it
  9. djranier
    I do like the gun setup, with the slower speed of the boat, at least you will make the fast boats pay to chase you. ;).
    Making the stern guns right now for my ship, hope its ready for the may battle in Statesboro.
    I have to totally refit the Kumano drive system, at the Bru I ran it like usual, but in one day, 4 battles, broke 4 different dog bones, kept getting the props tangled up with the props on the Allied boats, usually QE's. Going to direct drive I think.
  10. Anvil_x
    How will that help the cause? just removing the nylon dogbones I imagine will remove a point of failure, but where will that stress be expressed when the dogs are out? I've my shafts running through some GB500s, and have been a bit unnerved by how much my props project out for pretty much thee same reason you're toughening up your rig.
    I was thinking of amending it by switching to smaller props
  11. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    I have disliked dog bones from the first battle I went to. I saw 2 ships have issues and decided it was u-joints or couplers for me. They are obnoxiously noisy to boot.
  12. rcaircraftnut
    Oklahoma
    So is the gearbox in my Scharnhorst. But I ain't trying to dodge enemy subs with hydrophones lol.
  13. SteveT44
    I don't know if it's the innate engineer in me, but the wine of miss-aligned gearboxes and dog bones just sends daggers into my brain! :bang:
    Anvil_x and buttsakauf like this.
  14. rcaircraftnut
    Oklahoma
    I agree however gearboxes are sometimes just noisy. Especially if they use straight cut gears. As in my Sharnhorst. Noisy but strong and lets me run 2 j550s on a single shaft with a big 5 blade high pitch prop. Great acceleration and steering.
  15. Kevin P.
    Slowly plugging along. I’ve been resheeting the fleet. Lots of balsa, silkspan, and contact cement.
    Balsa for 3 capital ships
    Sides on
    Whole ship
    With deck pieces on. Starting to look like a ship
    Hopefully more progress in the next few days
  16. rcaircraftnut
    Oklahoma
    I need to sheet two and resheet one soon.
  17. Beaver
    Heh, I get grouchy when I only need to sheet ONE of my boats, and none of them are over 3 feet long! Guess I need to suck it up. Lol ;)
  18. rcaircraftnut
    Oklahoma
    None of mine are under 5 ft lol.
  19. NickMyers
    Lopped a bit off the Suffren or mothball it already?
  20. Kevin P.
    Nasty ram
