Agincourt build (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Sep 10, 2017.
  1. Kevin P.
    Progress
    Made stacks, tripod accessories. I’m loving the ‘good enough’ approach
    Build area is becoming tight with the Courbet project haha. Will be better when the parts come together. Had to get creative for epoxy rack
    Other side, turrets ready
    Coated in epoxy, thinned it a bit with acetone for weight, spread out nicely
    Drying
    Looks like work is back on tomorrow, so I’ll try to finish up wiring, and maybe a couple other things, complete for sea trials Saturday
  2. Kevin P.
    Looking more like a boat
    Zip tied on the forward side mount finally, very simple mount with magazine protection
    The aft float is brought to you by the number 8
    Three layers on mat, fiberglass top. Was planning for a internal spool but geometry it tight. Might be not attached for now, or I’ll tackle it in a couple days
    All superstructure in place
    From stern
    Now just need to paint and it’ll look like a boat. Also need to mount turrets after paint. Getting CO2 now, will probably paint when I get home
    rcaircraftnut, NickMyers and Beaver like this.
  3. Kevin P.
    Painting upper portions complete
    SS and deck gray first. This is post gray
    Then deck. Can never get the color quite right
    Pulled tape and paper
    Now with turrets in place for show
    No barrels yet, those will come tomorrow with gun testing
    Overall only a few spots to touch up
    Another aspect. Red will come when I float it and mark waterline, need a pond
    Final touches on wiring, co2 hoses, motor install, lots of other small things tomorrow
  4. Beaver
    Will you be bringing her to Nate's?
  5. Kevin P.
    Yes, that’s the plan, Statesboro first.
    Put in barrels
    Stern
    The T to line up the stern guns. Took idea from better builders. Also added gun pin and turret tethers. One of the things don fisher told me on my first trip to his house about 15 years ago. Have everything attached, not too long that they can foul props, but makes for cleaner recovery if you sink out from shore, no parts floating away
    Ship
    Fed sidemount. Might adjust more to the side in the future
    Too much light
    Comparison to Seydlitz. Similar size
    Sterns. Turrets are further aft
    Needed to canab the control box, other one will go back in Missouri
    Hot swap
    Done
    Wired up motors. 550 variant
    Tight with pumps, planned for out runners
    Gearboxes, good access to motor screws is nice
    Float anchor
    Spacing was planned
    Hooyah
    Spiral wrap on wires
    Fully loaded. Pump batteries in parallel
    Bow, one bat for drive
    Came in 24 lbs 10oz which is good, max is 26 so battle weight should be near there
    Balanced on a level to anticipate trim. I think that’s right at center of floatation I measured at the beginning, so it should only require minimal tweak on the pond
    Turret mounts, one tube inside another, generally works for me, isn’t a home run and typically might take a few tries to get all the turrets good
    Taped down while the hoop on the lower tube dries
    I think co2 lines are the only thing missing inside, will do in am. Sea trials tomorrow. Also gun test. Oh I did a full operational bench test, all SAT. Good day overall, should be set for Statesboro unless major issue tomorrow
  6. Anvil_x
    Oh I'm stealing the tube inside a tube turret mount idea. that'll do her.
  7. Kevin P.
    Initial sea trials photo dump
    Dropped in co2 lines this morning
    Kinda just made it work
    Bottle removal should be painless
    Gun hoses too. Everyone follow? There will be a quiz on connections later
    Here is the turret mount up close, large tube gooped to barbette
    Draft markers to judge freeboard during float test. Too big for the tub
    Pond 1 was mossed, so I went to backup
    Float test was good, very level, bow was high so I had to add a good deal of weight to get it down
    I think I added a wrench after this picture, still too high here
    Looking better
    Looks like an iron duke kinda
    Stern aspect. Axis might have soggy depends now, allies aren’t supposed to have two stern side mounts.;)
    Performance was good. The backwards props make reverse acceleration ‘axis-like.’ Turning isn’t horrible for the length/1 rudder. Didn’t leak much which is a good start. I shot a video that I may post later if I get around to it. Off to dry it out and test guns. Also need to add more permanent weight on very bow, paint bottom, add waterline
  8. Bob Pottle
    Looking very good Kevin!
  9. Kevin P.
    Thanks bob. A few more pictures from this afternoon. Tested out guns, had one small co2 leak to fix but overall guns were good. New chrono worked really well too.
    Mounted float spool. Line here is 50 lb braided fishing line, should theoretically be able to lift boat with this. Didn’t use my normal 3/32 line because of space
    E6000 to hold it on, should be good enough
    Here are the lines to the mounts in the hull, generally around center of gravity.
    Painted the rest of the bottom. Looking better on the bench
    Will tape waterline tomorrow, I have some battery holder pieces to e6000 to the hull, should be about it, might run some more rounds through the guns
    Nate G, SteveT44, Beaver and 2 others like this.
  10. Kevin P.
    Added waterline, the spool mount dried, just have some battery guides to goop in. I always like the look with the waterline
    Not a ton of freeboard aft
    Other side
    Aft, dark
    Nate G, rcaircraftnut and Beaver like this.
  11. Commodore
    Commodore Well-Known Member
    Sunny TX
    Nice! Get some pictures on the water before it gets all shot up, okay?
  12. Anvil_x
    Kevin, you coming to the October shindig in Saranac? It'd be cool to see that rig in person if you are
  13. Kevin P.
    Thanks Chris, I will get pictures. And yes I am planning on making the October battle, probably bring Agincourt and Seydlitz, don’t want Kas to be able to run away ;)
    Anvil_x likes this.
  14. Kevin P.
    First couple battles are in the books at statesboro. So far so good
    The big axis boats couldn’t make it so Missouri stayed in the car, and Agincourt got the start
    Waterline was a little high in the bow, filling the bottle helped bring it down
    She looks pretty good, everyone thought my iron duke looked funny
    Port
    speed trials were good, ended up around 45% throttle which was kind of expected. She makes a nice wake through the water. 24 sec would be nice
    First battle was axis vs allies. Allies were Brian (qe) me Phil and John (gearings) vs Chris (Baden) mike (veritie) and Wes (PE). Took some time to get the operator trained to shoot the correct gun, my square button pattern isn’t great, and with the extra stern sidemount I ended up swapping my normal lineup. I ran the ‘all stern’ lineup with bow sidemount pinned
    Took some damage, but gave some too. Believe this was mike, we had some good side by side exchanges (with Chris also)
    I got Wes pretty good with the stern guns, they were a crowd pleaser
    Chris’s Baden
    The scores are probably close, mike sank late fit to pump failure which might have swayed the outcome. I ended up with about 50-10-34, fresh balsa was holing nicely so she was fine with just one of the pumps, but having the extra half unit is a morale boost for when she was looking low at one point. Barely put anything back into the pump batteries, about 2500mah total between the two packs
    Second battle we got 3 more ships out, generally the same sides. First sortie Brian and I sank the other team (well sank Chris, two other mechanical failure sinks). We squeezed in a second sortie before thundershowers came through, again good outcome for the allies. Chris was beating up on one of the DDs that got stuck on shore, so Brian and I got him back. Here was the aftermath
    This is just one side, it will be interesting to hear the numbers tomorrow
    Plan is to mix up teams tomorrow, hopefully weather holds. Two of the DDs and Wes all had on board cameras so hopefully that video makes it out at some point.
  15. Panzer
    Hell, MI
    Shoot KP, I dont care what Steve T. says about your building skills, that is a great looking ship(even if its allied, Im axis so i might get lynched for this) Looks like it functioned close to as planned. So, congrats on another great Build. I appreciate that you share your Builds and battles with all of us so we can learn from your experiances as well.
    Hope to see you on the water.:):)(not under it);)
    Craig
  16. SteveT44
    What did that bastard Steve T. say about Kevin's boats? ;)
    rcaircraftnut likes this.
  17. Anvil_x
    Hey tell Phil and John to shoot me an email when you see them. trying to coordinate a winter battle with them while I'm visiting family for christmas
  18. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    Boy, the waterline seems a bit high on that last set of pictures.
    NickMyers and rcaircraftnut like this.
  19. Kevin P.
    Thanks craig, she turned out pretty good. Phil and John headed out earlier so I missed passing your message, they did talk about needing to find a spot in Atlanta. And yes that was empty bottle and no BBs, but I’ll probably lower the waterline 1/8” on the next resheet.
    Got 3 battles in today.
    Here is a view of the pond from the pits
    Nice level ground
    Here is Brian’s Ajax with quad .5 unit sterns. He has nice 3D printed solenoid holders for an offset patern. He ran the Ajax today, quite successfully
    Some pre battle shots
    Starboard quarter
    Most of the fleet minus a couple
    First battle was a pretty even matching. The other side had one capital ship (Bayern) that sank pretty early due to pump issues, so I faced off against mike in the veritie and Brian in the Ajax. The worked well together to get me into T arrangements and Brian got some good passes in (I didn’t want to pull a Kas and drive 9 hours to just run away). My full unit pump outlet clogged and she sank with just the half unit going. She did sink nice and level which was good. Float deployed, only was in a foot or so of water. Here are some of the refrigerator shots
    Mainly above, but once they became belows with the half unit she was done
    Whole side
    Totals were about 80-15-25 if I remember. After unclogging the outlet I put her out again and she was fine to pump out from almost decks awash in a relatively short time
    Battle 2 was good, I tried to spread the love to some other ships, one of the DD’s found itself stuck near shore. So I got a solid pass in on it.
    She ended up with 14 belows but stayed afloat with the little half unit
    Second sortie we put a hurting on Chris, he was pumping full bore but hanging on for a while, I was on 5 but decided to give chase for a prop wash. Mike did a great job putting his boat between mine boat and chris’s, it was quite entertaining watching the on-5 prop wash defense. Eventually I was able to approach from the stern and get some water on the deck and Chris went down. We took down the PE earlier in the sortie, cruisers don’t belong near shore haha. Still had decent damage, about 50-15-35, balsa is still holing well for belows which meant all I needed was half unit pump. Still had some decent holes
    Third battle was free for all, I think I traded some with mike, Chris, some pot shots at Brian.
    I had to take this picture on the way out from the lake, Brian has been keeping a lot of boats running (along with running an excellent event)
    Plan is for a quick battle in the morning before hitting the road. As of now the list of things to ‘fix’ is pretty short and minor
  20. Beaver
    Looks like a great event! Glad to hear the Agincourt did well, speaks volumes of the man behind it.
    Is the Tromp still a virgin?
