airsoft guns on boats
Discussion in 'Weapons & Pneumatics' started by The Texan, Apr 10, 2013.
  1. gunsnrosesx
    gunsnrosesx Member
    Didn't mean to offend anyone or the hobby, just saying seen it done, and was pretty cool. And if i were to know that this was 100% against it i would of never brought the idea about. Sorry for mentioning it.
  2. The Texan
    The Texan Member
    the magazines for my guns are in the barbette of the gun turret, would it be possible to have the entire turret barbette and all pull out of the ship to reload the magazines
    It would, but why not reload them with the turrets still in the ship?
  4. The Texan
    The Texan Member
    because the lower mazaines are in the bottom of the barbette, i only have one magazine in the upper part of the turret, plus i would like to have easy ascess to the everything for matainance
  5. The Texan
    The Texan Member
    also would arming the tertiary battery be possible
  6. The Texan
    The Texan Member
    How big is your budget?
  8. Kotori87
    Possible? Certainly. Practical? Almost certainly not. From both the mechanical and operator standpoints, adding the secondary and tertiary guns will add a whole bunch more possible failures for negligible benefit in combat. Get your main battery working, then consider extra features. If you still want secondaries, plan ahead and save the space for them - but don't build or install them yet.
    Have you looked at the cannons used in airsoft tanks? There are a bunch of 1/16 scale WWII tanks around that have a compact airsoft cannon in them. Given your intended scale, those may be more suitable than stripping down a bunch of regular airsoft guns.
  9. The Texan
    The Texan Member
    no i had no intentions to but was wondering if it could be done
  10. The Texan
    The Texan Member
    I was looking at the gun arrangement on the Scharnhorst and the 11 inch rifles simply are to small so i'm doing the 15 inch gun conversion with two different bow pieces for accuracy in scale as well ad dummy triple turrets for show
  11. gunner250
    gunner250 Active Member
    Missouri
    why not just have it co2 and set up like a regular big gun cannon it would probley work
  12. Tugboat
    Because airsoft guns don't use a CO2 firing mechanism, and the amount of trouble it would be to convert one is far more than the amount of trouble that it is to build a cannon by itself.
  13. Reckless
    Reckless Active Member
    Ladysmith BC
    actually there are several CO2 airsoft systems .. they've even got into electro magnet firing systems completely programmable .. but I do fully agree for the cost and utter hair pulling frustration retro fitting these systems to Combat ships would be so counter productive and overly complicated (the electro mag programable kits are somewhere in the 1500-2000 dollar range)
    on that respect though I've got a couple of cheap electric pistols that I thought about reverse engineering for BB cannons ..could even do barrel recoil LOL ... but I can pretty much garuntee their reliability would be counted in shots ...not even battles or days
    airsoft stuff is ment to fling a .2 to .48 ish gram 6mm BB normally.... not the heavier stuff combat ships sling ...
