1/144 American Destroyer Fletcher 1.0
Fletcher Class Destroyer Plans
  1. Beaver
  2. DATDAVFred
    DATDAVFred Member
    cincinnati ohio
    silly Q. how many units would this be ?
    4 ?
  3. NickMyers
    Treaty shiplist says 1
  4. DATDAVFred
    DATDAVFred Member
    cincinnati ohio
    wow, ok thanks, for info.
  5. Michael Von Zechlin
    Michael Von Zechlin New Member
    Sacramento CA
    Having a heck of a time printing the document to a 1/72 scale or even the 1/144 scale so that I can use dwg as a pattern for the frames. Losing too much clarity on the cut and paste to word to get something that is usable for production - how do you guys do it?
  6. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    I use a FREE program called GIMP a lot of tutorials on YouTube . If your original is a low resolution you can only clean it up only so much. Make a transparency retrace the IMPORTANT lines. always check your length and beam measurement most online plans and some printed are distorted.*
    *this is a generalization not ref to Beaver post;)
  7. SnipeHunter
    I've used a program called Data Thief to recover hull stations from bad plans. It was created to pull data out of academic papers graphs so it takes a little futzing with but is pretty easy to use.
  8. Gary Powell
    Gary Powell Well-Known Member
    Northern California
    Michael:
    I have some USS Fletcher plans that I can give you. We have an event in Auburn this Saturday the 9th. If you can make it, I will hand you a set already printed to scale. Gary
  9. Gary Powell
    Northern California
    I should also add, we have a complete USS Fletcher hull and superstructure floating around that you could probably buy for $50. You would then just need to install the internals (guns, radio, battery, etc.) Gary
    Morgen Anthony and NickMyers like this.
