Axis Doom ->Tromp build
Discussion in 'Warship Builds' started by Beaver, Jan 27, 2018.
  1. Ralph Architzel
    Ralph Architzel Member
    Derwood
    ok with stopping the hijacking but i would like to know what hull you got/are cutting.
    i ordered a northhampton ship kit from strike but steve is taking a long time to get it out to me.
  2. SteveT44
    That's a 1.5 unit Tromp CL hull that Kevin is now producing.
  3. Ralph Architzel
    Derwood
    Sorry for still hijacking but I wanted to know what AdmiralBanger bought/is gutting up out of curiosity
  4. AdmiralBangerBang
    AdmiralBangerBang Active Member
    Long Island
    Oh, I'm building a wood hull FN Suffren (Named the FN Beaver)
  5. Beaver
    Progress for the week.
    I made the decks and glued in the stuffing tubes, though they are removable. More on that further in the post.
    Here's the ship with the decks. I used 1/32" fiberglass sheet with magnets to hold it down. So far, it looks like it will make a good seal.
    Stole Steve's idea of using pins to keep things aligned.
    Just realized I don't have any photos of the shafts. Anyway, to make the stuffing tubes removable in the future I gave each one a wrap of packing tape before I epoxied them in. West Systems doesn't stick to packing tape so I easily popped each shaft out after the epoxy had hardened. After removing the tape the stuffing tubes slide back into the ship really easily without much slop. I plan to seal the shafts in with a thin coat of E6000, but that can easily be peeled off if I ever want to remove the shafts or pull the gearbox out.
    Here's some photos of my planned internal layout.
    Bow area.
    Midship.
    For the gun I'll be using my newly developed gun for small ships. Its design allows you to keep the weight of the tee and full magazine low in the ship if you choose. I need to lengthen the mag on this one for a full unit gun. If anybody is interested in the details I can post them up.
    That's it for now...
    Kevin P., rcaircraftnut and SteveT44 like this.
  6. Anvil_x
    with that design, do you think it might be possible to get that gun even lower by bending the barrel to accompany the bend in the neck? you probably don't need to bend it any further for your purposes, but I'm more thinking for future projects
  7. Beaver
    You 'can' bend the barrel, but if you do you'll need to use a barrel that can take the wear. (heavy ss or steel) with this gun I'll be using an aluminum barrel which couldn't take the wear of bbs constantly hitting the bend.
  8. Panzer
    Hell, MI
    Very nice work on this Beaver, love the info you are sharing to help other builders. The speed at which you are going is amazing(to me). You do great things!
    Hope to see you at a battle in 2018! Nats in Lancing a possibility???
    Craig
  9. rcaircraftnut
    Oklahoma
    I need to get a week off and come hang out with Beaver, imagine what the two of us could come up with locked in a fully stocked shop for a week. Maybe we should have a fund raiser for that, call it an investment in the technology of the hobby, lol.
  10. Anvil_x
    lol you could always do what I've been doing for the past two years: work a seasonal position for 60-80 hours a week for half the year and save like a squirrel to free up your winters.
    Seasonal wildland firefighters make BANK overtime and get november to may off.
  11. Beaver
    Thanks for the kind comments. You all flatter me beyond my scale. :)
    While I'd love to, it probably won't be going out of the local circuit this year. Maybe next year though. :)
  12. Beaver
    Rudder setup is finished.
    I mounted the servo with magnets. With that setup, I can change a servo in a few seconds.
    Rudder and props.
    Rudder throw.
    Hopefully she turns ok.
    With the plan being dual bow guns, I've changed a few thing with the internal layout. Mainly, the battery is now moved aft to between the stuffing tubes. Fits nice and snug.
    Later...:)
    WillCover likes this.
  13. Kevin P.
    Might want to shift to dual sterns, initial stability tests on mine weren’t great, I’m making a few changes and will try to stick with bow guns for now
  14. djranier
    What happens when the rudder hits a rock along shore, and pops the servo off the magnetic mount? Are you adding a box around it to hold it in the general area of the magnets, so they can lock down again?
  15. Beaver
    In the testing I've done so far it pops right back on when it's knocked off. I'm still in the proving stages though, so if it becomes an issue I'll take countermeasures to keep it in place.
  16. Anvil_x
    well then. that's groovy. I'm surprised the magnets don't mess with anything.
  17. rcaircraftnut
    Oklahoma
    Modern electronics are pretty much immune to small variations in magnetic fields. Witch is nice, as it opens up a lot of new possibilities for mounting ect.
  18. SteveT44
    The bane of class one raises it's ugly head. Keeping these little hulls pointing straight up is a challenge. On my Mogador, I thought I'd experiment with a 10 degree offset bent barrel on the aft single. This was enough to list the boat a good ways. Go with plastic mags and aluminum barrels to lighten your topside up.
  19. thegeek
    Titanium is the only way to go with barrels. At only $40 or so a foot, not bad.
    rcaircraftnut, absolutek and SteveT44 like this.
  20. Kevin P.
    It's like you can see my pending mcmaster orders. Titanium is only $14 a foot, about the same as 2 SS barrels
    rcaircraftnut likes this.
