Axis Doom ->Tromp build
Discussion in 'Warship Builds' started by Beaver, Jan 27, 2018.
  1. Beaver
    I need to update this thread. Tromp has gone through some changes and has become a very feared spurt cruiser. She's getting a refit to become even more fearsome with probably the most ambitious load out for a ship this size. More on that later. Here she is ready for the 2022 nats with her sister built for @Nomercy.
    More to come....
    Panzer, Nomercy and darkapollo like this.
  2. Beaver
    Here's one of the biggest innovations and improvements to Tromp as a spurt cruiser, no co2 supply. The 12g adapter and BC reg have been removed from the boat in favor of two copper accumulators with check valves. Charge off an external reg before battle and you're ready to do some impressive damage to an opponent! The gas/$$ savings is excellent as well. Turn around time for campaign is faster and the spurts seem more powerful than off a capsule. Very happy.
    notSoGnarly and vicious p like this.
  3. Beaver
    Another pic of the tank. Screws right into the solenoid.
  4. vicious p
    vicious p Well-Known Member
    Greensboro NC
    How many “spurts” per gun do you get before your empty or is it a one shot deal? How are you recharging the accumulator?
  5. Beaver
    It's one shot per trigger pull. Two half unit spurts in the ship so you get two trigger pulls but that's it. Tanks are charged prior to battle using a standard CO2 tank with a reg. I use a poppit valve on a piece of hose to make filling faster. Stick the hose in the 1/4PTC fitting, press the poppit to fill the tank, pop the hose off, SPURT!
    vicious p likes this.
  6. Kotori87
    Makes sense. A cartridge can get you the same number of shots per oz of CO2 as a larger bottle in theory, but it can't supply it as fast. So a sudden, large demand like a spurt firing would easily drop your system pressure. Two independent accumulators charged from a shore supply though, no limits. I bet that thing rocks at campaign.
  7. Anvil_x
    yeppers. and this isn't going to be the only boat so armed next year at campaign.
  8. Beaver
    Changing things up. After building a Tromp for @Nomercy and liking the brushed drive in that more than the brushless drive in mine I've decided to change it out.
    This required me to shorten up the stuffing tubes about 2in. Also going to try printed props this time.
  9. bsgkid117
    Hey I recognize those.
    Nomercy likes this.
