battery recommendations
Discussion in 'General' started by Powder Monkey, Mar 17, 2008.
  1. BoomerBoy17
    Will this work for my Graf Spee?
  2. SnipeHunter
    Probably much larger than you need, most cruisers are fine with 5 Ah. Buy if you have the weight then go for it.
  3. BoomerBoy17
    Is this better? I would only need 1? or 2? and a charger, obviously, right?
    http://www.batterymart.com/p-6v-7ah-sealed-lead-acid-battery.html
  4. SnipeHunter
    Cruisers are allowed to change batteries between sorties since they cant carry as much weight. I would suggest you take advantage of that. (that means you need 4 batteries and either 2 or 4 chargers depends on how clever you are.) If you have enough weight to carry a 7Ah brick then go for it, with cruiser batteries it pretty much all comes down to weight.
  5. BoomerBoy17
    im thinking 3 batteries and 2 chargers.
  6. SnipeHunter
    A normal battle day has 4 sorties, doing that with 3 batteries is questionable.
  7. BoomerBoy17
    Well, how long does a normal battery take to charge? remember these are 7 ah batteries, not 5 ah.
  8. BoomerBoy17
    It says that the charger can charge 4 batteries in tandem....so would i only need one?
  9. Powder Monkey
    I only had two for NATS and charged them during each sortie so while I was using 1 I was charging one I had no problems
  10. BoomerBoy17
    batteries? Cool monk, that helps. So 2 batteries, 1 charger?
  11. Powder Monkey
  12. BoomerBoy17
    thanks Fred
  13. the frog
    the frog Member
    An sla battery will not take a 1 hour fast charge like a nihm will. I think you will find that the 7ah lead acid is to big and too heavy for a cruiser.I run 2 3000 nihms in my suffren and put them on fast charge between sorties. they last all day.I have 1 5cell 6volt 10 amphr nihm in my other cruiser and I hit it between battles it also lasts all day
  14. djranier
    Rick from BC runs both his Scheer's on 6v, 7ah SLA's with no problem. In the new one, we even used 2 Kips solenoids which is a bit of weight themselves, but made sure we kept the weight down with a very clean build. The pocket BB's have just enough hull volume to do it. My Mogami was overweight with the SLA, so I had to go to Nmih's.
  15. Powder Monkey
    I ran SLA at NATS and was a tad heavy but now I run NIMH and it works much nicer weight and space wise but other that that no different in performance seeing as I was out of or under the water in short order so no endurance issues [:D]
  16. BoomerBoy17
    What batteries do you run Monk, where did you get them?
  17. Powder Monkey
    http://www.all-battery.com/two72v4500mahflatnimhhighpower40adrainratebatterypackswithtamiyaconnectorsforrccarsandsumorobots.aspx
  18. djranier
    If you want a better price, use the same store Powder does, but buy from their E-bay store. The same battery packs Powder listed for $64.99 are only $44.99. I have been getting all of mine this way.
    Visit this site
    Or even better price, with a little less capacity for 2 packs, $29.99. And with a charger for $46.99.
    Visit this site
  19. Powder Monkey
    Now you tell me LOL
  20. BoomerBoy17
    how many sets of batteries do i need? do you use both packs at the same time Monk?
    http://www.all-battery.com/two72v4500mahhighpowernimhbatterieswithasmartcharger.aspx
