Battle: July 18
Discussion in 'Washington Cascade Column' started by NickMyers, Jul 14, 2010.
  1. NickMyers
    Battle @ Cle Elum this Sunday.
    I'll be there with the Suffren and the Maru. My intent is to arrive between 10:30 and 11.
  2. Hovey
    Hovey Admiral (Supporter)
    Washington
    I'll be there with the North Carolina for you to try running over again Nick. I picked up a new tank of CO2 today so hopefully we can get a few more shots off this time.
  3. NickMyers
    poor little Maru... we should grab a video of it bouncing off the NC at full speed ahead
  4. Hovey
    Washington
    Poor little maru? The Suffren had some sort of bizarre steering problem, every time she got near she would t-bone the NC, lifting the Suffren out of the water as she rode up my deck! I think I suffered more damage to my balsa from that than enemy fir.
  5. NickMyers
    it was truly the damndest thing. must be some sort of local area effect. that tub of yours you call a ship seems to create a depression in the water, pulling in all nearby things
    I have a video of the NC ramming the Suffren - a second later the Insufferable sank - coincidence? i think not.
  6. NickMyers
    besides, you're not using the balsa in that top 3/8" - i was using the balsa that andrew rammed a hole through!
  7. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    Im going to try to be there with the Bis. Its not going to look its best but it should still do some damage.
  8. NickMyers
    great to hear. cle elum should be a great pond for the bis, lots of space
  9. Hovey
    Washington
    Tub? OK, maybe she isn't the best looking ship on the water but she sure turns nice. Someday I will get around to painting her. I only rammed you because the I-Boat was in trouble and I was watching her in case she went down. I am still new to battling after all so rookie mistake.
    Alex, I think you will like the open waters at Cle Elum. Its a great pond for the big ships to play in. Just stay away from Nick and his goofy special gravity theories.
  10. NickMyers
    Those are only in effect when I'm out of bbs and near you. He has functional sidemounts :)
  11. tgalx3
    Snohomish, WA
    Should make for fun times. I have been out to those ponds before but not with a big ship. Is anybody bring CO2?
  12. Hovey
    Washington
    I have a fresh tank.
  13. Hovey
    Washington
  14. tgalx3
    Snohomish, WA
    ok I didnt have time to get my tanks filled.
  15. NickMyers
    Today was not my lucky day. Sunk twice in different ships... have some fun pictures of the sinks though, sadly not of start to finish, hopefully the videos provide some decent coverage when I get to them.
  16. Hovey
    Washington
    How is the camera?
  17. NickMyers
    Pulled the videos off it last night without a problem, haven't popped batteries in yet to check that it has full functionality. I'll probably open it first and visually inspect it to make sure its clear of all pond water, scum and other residue first.
    I think I'm pretty much done with the flipcams on tripods idea, and not because of the dunking this one got. The video is just lacking. Without an operator to follow the action too much occurs offscreen at times, or far away, or right under the camera it can bea bit frustrating to try to follow whats going on. It would be good supplemental footage to splice into a video if we had a live operator on shore, following the action, zooming where appropriate, etc with another camera.
  18. tgalx3
    Snohomish, WA
    I can make both the battle dates you quoted Hovey
  19. NickMyers
    Selected Pictures from the event!
    The Maru, all patched up and ready for a bath
    The Bismarck looking good
    Suffren shows its ability to roll in any turn, no matter how small
    The North Carolina showing off how tight she can turn
    Fresh onto the water, the Maru decides to try to bully the North Carolina
    The Maru finds herself in a bad position, falling behind her escort
    The Bis arrives on scene and stays between the Maru and the NC
    The wolves
    During Sortie 2, the Suffren slides under not longer after having her stern pushed under by the NC
    Sortie 3, the NC moves to escort duty
    NC denies the Bismarck
    The Maru pumping itself back towards the waterline
    Maru settles lower, the pump isnt getting the water flow it should - I think it suctioned onto the bottom of the hull (oops)
    The raider Bismarck glides by as the Maru takes a trip to the bottom
    Down to Davey-Jones' Locker!
    The NC opens fire on the Bis
    Sortie 4, The Maru parked next to the Bis for refueling Ops. Shes missing a mast and her stack which came off during recovery operations.
    The wolves close in on the Maru who scurries to catch up to her escort
    Caught alone!
    This is how we roll - you need a good deck seal to play this game!
    Yar!
  20. Kotori87
    Those are some impressive photos. What a beautiful place to battle! I'll bet Mehoshi looked great on the bottom, with such clear water.
